the spout that is circled is right under the heater core and and its the only one under there. it leaks radiator fluid and spits out. does anyone know where if and where this should be connected to??
Wild guess is this is the condensation drip tube from the AC unit. The picture is too close to be sure. I'm guessing this is inside the engine bay against the firewall on the passenger side.
If it is dripping radiator fluid(green, red, Rusty?) then you probably have a heater core leak. Otherwise, it should just drip clean clear water when the AC is running.
Good Luck,
Jim henderson
right on thanks Jim thats exactly what is coming out of it. well time for a new heater core as well!!
