Headlights don't work...
Old Mar 31, 2003 | 11:35 AM
fiveptO's Avatar
fiveptO
my headlights do not turn on. The parking lights work fine, as does the blinkers and the high beams work only when you "pull" the lever twords you. When you push it away from you (to lock the highbeams in the on position) it doesn't work.
Recently, i had to jiggle the highbeam handle around to get the low beams on, but that doesn't work anymore.
What should I look for/ Replace?
Thanks,
scott
Old Mar 31, 2003 | 11:45 AM
winfordr's Avatar
winfordr
Sounds like a defective headlight switch. If the lights work when you pull the lever, both low and high beams should be on. That would eliminate wireing problems past the switch.
Old Mar 31, 2003 | 08:41 PM
steve83's Avatar
steve83
Not the headlight switch - it's the MultiFunction Switch (wipers, signals, hazards, & hi beam). They're as little as $20 at some parts stores and not hard to replace. They can be repaired, but it's a huge hassle.
