400 expert advice needed
Old Mar 30, 2003 | 11:19 PM
Noxious's Avatar
Noxious
ok here it is.......i have a '72 400.....i want to make 400hp and 400+lbs of Tq......heres what i have blueprinted so far
.030 over pistons from Badger 9.5:1CR
Weiand Stealth or X Cellerator Manifold Non-EGR
Edelbrock AVS 650cfm carb
Comp Cams Xtreme cam
specs: Adv.268/280 Lift:509/512" full roller and the optional kit ofcoarse dont wanna mix an match parts
Comps roller rockers 1.72 ratio
Milled heads most likely to .025
static CR should be about 9.98875 if my math is correct
MSD 6AL ignition system
K&N Filter
thats about it........do you all think this will make 400hp at the rear wheels? if you dont or see something that could improve the hp id be very greatful if youd let me know
thanks all
Old Mar 31, 2003 | 04:22 AM
shazam's Avatar
shazam
I would say that this set-up would make 400 H.p at the flywheel easy .. but to the rear wheels I'm not sure ??? theres so many things that can zap Horsepower away in the drive train....
Old Mar 31, 2003 | 04:53 AM
Noxious's Avatar
Noxious
very true Shaz....any ideas on how to cut drive train power loss?
Trans is a C6
rear end is a rare (first one i've come across)open 8.7" with 2.73 stock gears
i want to upgrade to 3.73 gears an put a locker in them retarded open rear ends
Old Mar 31, 2003 | 05:10 AM
shazam's Avatar
shazam
Well in the Truck Pulling Commuity a C6 cost about 50 H.p. So I'd start looking for a Standard Tranny Np 435 or a T-18...
Old Mar 31, 2003 | 07:06 PM
Matts72's Avatar
Matts72
I always thought the C6 ate more like 85HP, you aren't losing more than 5 HP in your rear end though the gears are relatively easy to turn.
Old Mar 31, 2003 | 11:44 PM
GT40man's Avatar
GT40man
a quick look at dd2k
stock valves
417hp @ 5k - 464tq @ 4k - single plane
401hp @ 3.5k - 463tq @ 3.5k - dual plane
4V valves
439hp @ 5.5k - 472tq @ 4k - single plane
418hp @ 5.5k - 467tq @ 4k - dual plane
this is est. at the crank
10:1 cr, 4V vales, and porting
484hp @ 6k - 492tq @ 4.5k - single plane
458hp @ 5.5k - 481tq @ 4.5k - dual plane
all of these are with headers
Old Apr 1, 2003 | 12:28 AM
MustangGT40's Avatar
MustangGT40
GT40 what do you use to get those numbers?
Old Apr 1, 2003 | 02:48 PM
78bigbronco's Avatar
78bigbronco
What powerband are you looking for? That intake manifold and cam will be awsome towards the top end but I hope your not puttin it in your dialy driver heavy truck lol. Also if what your are looking for is top end then I hope your throwing a set of headers and free-flowing exhuast on it. Just my $0.02
Old Apr 3, 2003 | 07:21 AM
Noxious's Avatar
Noxious
no more tips for poor ol me?
common give me some tranny tips.......ps i wanna keep the C6 so lets get this thing runnin u know?
Old Apr 3, 2003 | 08:05 AM
shazam's Avatar
shazam
OK Keep the C6 and just go to 4.11 gears ....will help make up the lose ........
Old Apr 3, 2003 | 09:40 AM
beartracks's Avatar
beartracks
A 2,300 rpm stall converter will really get you off the line faster.
Old Apr 5, 2003 | 02:03 AM
GT40man's Avatar
GT40man
dd2k - deskto dyno 2000
these are not acutare, to get better numbers i need the head flow data. but its a rough guess.
