what do you do while you oil is draining ?
Old Jul 21, 2011 | 08:50 PM
njneer1's Avatar
njneer1
In light of the new what are you doing while filling thread...
Old Jul 21, 2011 | 08:57 PM
tims01's Avatar
tims01
watch the guys at jiffy lube stay away from my truck only an oil change for me buster . cost $64 with military discount cheaper than doing it myself
Old Jul 21, 2011 | 09:24 PM
phoneprincess's Avatar
phoneprincess
I am going to have my oil changed on monday. Ill report back to you on that.
Old Jul 21, 2011 | 11:29 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
how so? lol i buy 6 quarts of mobile 1 synthetic and a filter i'm in about $35 thats a difference!
i normaly wipe my arm off because i allways end up with a nice amount on me..doesnt matter how hard i try to not let this happen lol
Old Jul 22, 2011 | 12:40 AM
vrinner's Avatar
vrinner
I give the under side of the truck a good looking over and maybe clean up a few things.
Old Jul 22, 2011 | 08:02 AM
LionFan's Avatar
LionFan
2nd that
Old Jul 22, 2011 | 08:06 AM
Bigpapa346's Avatar
Bigpapa346
I must say that it is easy to do it yourself.... I get out my creeper and get to work without having to lift the truck.. I look around as well to be sure everything is just as it should be.. functional!
Old Jul 22, 2011 | 08:51 AM
Macmathews's Avatar
Macmathews
He's adding 15 quarts
Real trucks, don't have spark plugs
Messin !
Kyle
Old Jul 22, 2011 | 08:53 AM
gr8scott72's Avatar
gr8scott72
Messin !
Kyle
Real trucks don't leave you stranded.
Messin!
Old Jul 22, 2011 | 08:56 AM
Immortal_Ben's Avatar
Immortal_Ben
I generally wipe the oil off of my hand/arm AND look around under the truck. Im multi-tasker.
Old Jul 22, 2011 | 08:58 AM
Macmathews's Avatar
Macmathews
gr8scott.
7.3 - not gonna happen !
Kyle
Old Jul 22, 2011 | 08:59 AM
gr8scott72's Avatar
gr8scott72
I could change my Durango without getting oil all over me. I had a Fumoto Drain Valve on it. I need to get one for my Excursion.
Old Jul 22, 2011 | 09:25 AM
Snowseeker's Avatar
Snowseeker
I go and grease all the zerks, give all the joints in the front end a slop inspection, check the brake pads all around for thickness, spin all the wheels to check for sticky calipers, check the rotors for hot spots or flaking, inspect U-joints for slop, inspect springs for cracks or broken leafs, inspect brake and fuel lines for leaks or bad rust areas, inspect fuel tanks for leaks, inspect seals at front and rear of motor, trans, and rear end for leaks, check tire pressures, check bushings for deterioration and cracking, look over the bottom of the radiator and other coolers for signs of leaks, and finally reinstall drain plug and wipe up extra oil and wipe it all over the rust on the oil pan to stop it.
Old Jul 22, 2011 | 10:02 AM
rufushusky's Avatar
rufushusky
I fill the oil filter with fresh oil, listen to the radio in the garage...drink a brew...nothing very productive...unless it is the third oil change. I will change the fuel filter...other than that I am a glorified space heater.
Old Jul 22, 2011 | 01:01 PM
tims01's Avatar
tims01
um the 7.3 excursion hold 16.5 quarts of oil the cost would be $ 110 and thats wallmart prices jiffy lube is $94 and when i do go in they give me the super discount cause i do all my vehicles same day
