Replace Hpop ?
Old Jul 21, 2011 | 05:23 PM
cdev's Avatar
cdev
Replace Hpop ?
been working on my 6.0 hpop due to low presure in hpo system (125 psi)
figured it was the stc fitting
removed the hpop looked like stc fitting had been replaced
the Blue oil seal looked new and the stc fitting looked the same as the kit
the pump sometimes has a metal to metal sound when you turn the cam wheel so im guessing the pump is gone
also lots of metal fillings on the IPR valve
i have another pump i can install and a stc fitting
is there anything else i should be looking for before i start putting the truck back together
new oil cooler coming tomorow
thanx fore any help
Old Jul 21, 2011 | 05:29 PM
npccpartsman's Avatar
npccpartsman
Hopefully you got a new IPR valve or at least a new screen for it. If I was in that deep I'd replace it as it doesn't take a lot to screw it up.
Old Jul 21, 2011 | 05:48 PM
cdev's Avatar
cdev
got a spare from wrecked 06 no fillings on the screen but i'll replace it with the one i got
with the stc fitting kit
Loftatsea
Oct 17, 2015 10:24 AM
joe blow
Sep 19, 2015 01:33 PM
zeppelingto
Dec 23, 2014 06:23 AM
the_auto_tech
Aug 2, 2013 09:38 PM
