Rear Brake problem
Old Jul 21, 2011 | 04:15 PM
Sheryle's Avatar
Sheryle
Rear Brake problem
Hello Ranger folks,
I usually stay over on the 6.0 diesel site(almost always need help with the 6.0). Anyway I have a 1989 Ranger, 4x4, 2.9 EFI, auto, xcab that I am trying to put back on the road after sitting for about 3 years. Engine and trans service going well, but i've got brake issues. Drove it a few miles and the brakes locked. Let them cool 20 minutes and you could go again until you stopped a couple times and they'd lock. Pulled front calipers, cleaned and greased including slide pins. They were rusted, gunked up so I thought I had it solved. On test drive they seemed to work okay but no rear brakes at all. Pulled the rear wheels, shoes and wheel cylinders. It all looked about as bad as the front, neither wheel cylinder would budge. Went to NAPA got new shoes and wheel cylinders and started changing out. All this history to get to here. Wheel cylinders looked dry, pumped brake peddle and nothing out of either brake line. By the way the peddle feels good and fluid is topped off. No issues visual with the brake lines to the master cylinder. Thoughts?? Any opinions or help appreciated.
Old Jul 21, 2011 | 07:00 PM
michigan66's Avatar
michigan66
I would suggest that you loosen the brake line fitting that goes into the RABS (Rear Antilock Brake System) and pump the brake pedal. Do you get brake fluid coming out? If so, then loosen the fitting on the outlet side of the RABS unit and again pump the brake pedal.
My guess is that you have fluid under pressure going into the RABS unit but not coming out on the outlet side. If that is the case, the best cure is to replace that component. O'Reilly's carries the part (remanufactured with a lifetime warranty) for about $130 plus a $50 core charge. They call the part an ABS hydralic valve. Other parts supplier may also carry a replacement unit. Ford's new unit is about $330, if you can find one.
I've just gone thru having my RABS valve replaced. The O'Reilly part was installed.
Hope this helps you.
Old Jul 21, 2011 | 09:34 PM
Sheryle's Avatar
Sheryle
Thanks Michigan. I will try that tomorrow and report back
Old Jul 21, 2011 | 11:21 PM
cj06's Avatar
cj06
if you had a lot of rust then i would look at the steel lines being filed with rust , undo the lines after the RABS and see if fluid is going through the RABS , if so then the lines or at least the rear rubber brake line is bad !
Old Jul 22, 2011 | 09:44 AM
tomw's Avatar
tomw
I would check that fluid is exiting the master cylinder before going further down the line...
If the master is bad, being it is a separate system front and rear, you could have the front working the calipers, but the rear dysfunctional. Not too expensive, just a pain to replace.
tom
