crankshaft timing sensor ,test?
Old Mar 30, 2003 | 09:51 PM
lazz20024's Avatar
lazz20024
i have a 90 ranger and it wont fire i have allready run a owms test
on both coils they check out fine my ? is how wood you check the
crankshaft timing sensor to tell if its bad?? any suggestions will be greatly appriciated thks lazz20024
Old Mar 30, 2003 | 10:46 PM
big1's Avatar
big1
If it's the two wire set up just do a continuity on it as you crank over the engine. Be careful here.
Old Mar 31, 2003 | 10:08 PM
lazz20024's Avatar
lazz20024
thk you for your reply but i went to my local autozone and they tested it for me turns out it was good still no word on how to test the sening unit by hand but if i hear of one ill post it for others to see, also i had the dis ignistion module checked at autozone and it turns out it was fine too. so tomorrow im going back to (A.Z.) and have both coils checked and see if the can check the trucks computer too ill post what happens tomorrow night. maybe i will help someone else having the same prob.heck i only have $100$in the truck but i want to hear it run next i guess im going to check the wiring harness for the prob if its not in the coils or computer,i will let everyone know as i make progress.
lazz20024
