EcoBoost (all engine sizes) 3.5L Twin Turbo EcoBoost V6, 2.7 Twin Turbo EcoBoost V6, 2.3l/2.0L I4 EcoBoost Engines
Long Term Trims don't match on for lean/rich
Old 07-21-2011, 09:16 AM
thomastl's Avatar
thomastl
thomastl is offline
I have some software and connector that allows me to monitor the engine and check codes.
I hooked it up and was monitoring the engine on the way to work today. I noticed several times that the long term trims did not match.
Trim 1 would read 5.7% lean
Trim 2 would read 1.4% lean
Then at the next update it would go back to 3% or so on both and hold for a few updates. Then it would go back to a different readings again. Then next update back to matching.
I also noticed on the short term that a lot of times bank 1 would be leaner than bank 2.
Is this normal or is this indicating a potential problem and could possibly be why my highway fuel mileage is around 17 to 18 at 74 mph cruise set.
Old 07-22-2011, 01:13 PM
cartmanea's Avatar
cartmanea
cartmanea is offline
74mph is probably the cause of your poor mileage. The rated numbers are for under 65mph I believe.
Old 07-22-2011, 09:35 PM
excaliber551's Avatar
excaliber551
excaliber551 is offline
Actually the highway rating of 21 was achieved with the 3:31 gearing driving 48 mph on average.
Old 07-23-2011, 08:42 AM
truckerdude's Avatar
truckerdude
truckerdude is offline
you need to read a little closer. There is also a high speed test that is averaged in as well as NO where doe it say that the 3.31 axle was used
Old 08-07-2011, 10:52 AM
trippen1999's Avatar
trippen1999
trippen1999 is offline
bank 1 and bank 2 are always going to be a little different.mine is the same way,i have been monitering using my dashhawk.the trims are the ecu correcting for minute differances inharent to all engines.as long as your ltft are +/-8to10% your good.
sawduck
1983 - 2012 Ranger & B-Series
03-24-2019 11:10 PM
Josh Lee Ponish
1997 - 2003 F150
02-06-2017 01:35 PM
Vizzle
13
12-14-2016 05:25 PM
tobyw
Modular V10 (6.8l)
19
11-02-2015 09:56 AM
Eetchickn
Modular V8 (4.6L, 5.4L)
07-07-2015 04:01 PM
Quick Reply: Long Term Trims don't match on for lean/rich
