Proportioning Valve Replacement
Old Jul 20, 2011 | 08:14 PM
MASROP05's Avatar
MASROP05
I have a 78 F150 Ranger Lariat- 4WD- disc front/drum rear. My son and I are rebuilding the truck and overhauling the complete brake system. I am in search of a Proportioning Valve, but have not had much luck finding a replacement. Some aftermarket stuff, but with little description to understand whether they would be a good replacement or not. I research here a little and found some posts from 2009 but most of the links no longer work or they no longer have parts.... Can anyone point me in the right direction please.
Old Jul 20, 2011 | 08:27 PM
montana_highboy's Avatar
montana_highboy
Aftermarket Pro Valve
Old Jul 20, 2011 | 08:30 PM
PA74F250's Avatar
PA74F250
What about just going to Napa for a stock replacement?
Old Jul 21, 2011 | 01:46 AM
k-member's Avatar
k-member
Now lets say a guy finds one off a 250 disk/drum? Would something like that work do to the fact the 250 caliper is double the size of the 150? Just wondering myself as I am getting ready to do something similar...go from all drum to disk/drum on the 250, and I love learning and I am hoping the brake gurus can teach us all a few tricks.
Old Jul 21, 2011 | 02:07 AM
ford390gashog's Avatar
ford390gashog
Obsolete
I had to install part # HPV2F http://cgi.ebay.com/ebaymotors/BRAKE...#ht_1064wt_939 works better than the oem and fits like the oem with no modification!!! Much better than the junk cast iron valve that was stock!!!
Old Jul 21, 2011 | 04:46 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D5TZ-2B257-B .. Brake Differential Proportioning Valve / Obsolete
Last MSRP: $283.30 / Dealer net cost: $169.98.
COLLECTORS AUTO SUPPLY in Oroville WA has ONE = 800-414-4462.
GREEN SALES CO. in Cincinnati OH has TWO = 800-543-4959.
Applications: 1975/79 F100/150 2WD/4WD / 1975/79 F250 2WD with single piston caliper disc brakes / 1976/79 Bronco.
Old Jul 21, 2011 | 08:15 AM
sinistry's Avatar
sinistry
I ran into the same thing with my truck. I ended up using a wilwood adjustable valve. It works great so far and was only about 50 bucks
dyoungen
Jun 23, 2015 07:35 AM
JEDWIN
Feb 22, 2012 03:46 PM
mhopkins
18
Apr 9, 2009 07:54 PM
dweise35
Feb 8, 2008 11:29 PM
phoneman91
Apr 21, 2005 01:49 AM
