Texas Chapter Join Chapter, Leader: LibTimothy
7.3 problems Saginaw, Tx
Old Jul 20, 2011 | 03:13 PM
rwilkietx's Avatar
rwilkietx
Any with 7.3 diesel knowledge around Saginaw, Tx area? Truck died while driving. Acted like it ran out of fuel. Installed 2 new batteries, glow plugs, fuel pump, repaired harness.and clean fuel bowl and fpr. Cranks fast just acts like its not getting fuel. Need to find out how to check ipr, idm if anyone knows. I dont have a scan tool. Guess I will after this.
Old Jul 20, 2011 | 08:22 PM
plumber01's Avatar
plumber01
I think the Chapter Leader knows his shiznit pretty damn good on the diesels, Also have you posted this is the diesel forum here under your truck year? you may get some good advice there to in case Scotty (TX Chapter leader) is working to much to get back at ya quick enough
Old Jul 21, 2011 | 07:09 PM
F350-6's Avatar
F350-6
There's not much you can check on the IPR or IDM without a scan tool other than just pulling them out and apart and using your eyeballs to look for anything obvious.
So no smoke out the tailpipe while cranking? Does your WTS light come on and go off after a few seconds like normal? All other dash lights normal? Engine oil full? Why not post up in the 99-03 7.3 diesel section?
