Two vin tags ?
Old Jul 20, 2011 | 01:00 PM
429unibody's Avatar
429unibody
Two vin tags ?
F10BCBA2497
133 H F101 DZ4 G 06J
04800 1978 84
F11YRB31639
WB 131 B F110 Body K81 Axel A Trans F9
05600 172 4000 DSO A77762
Old Aug 13, 2011 | 02:57 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Two VIN tags
Originally Posted by 429unibody
F10BCBA2497 / 133 H F101 DZ4 G 06J 04800 1978 84
F10 = F100 2WD
B = 300 1V I-6.
C = Oakville, Ontario Canada Assembly Plant.
BA2497 = 1978
133" Wheelbase.
H = Dark Brown Metallic.
F101 = F100 2WD, 4,800 lbs. GVWR
DZ4: DZ = Saddle & Tan all Vinyl with Saddle Appointments / 4 = Styleside Pickup.
G = A/T, could be either a C4 or C6 (C6 first offered in 1978 as an option w/the 300). The G trans code was used by Ford thru 1978 for ALL A/T's.
06J: 06 = Dana 44 Rear Axle / 2.75-1 / non Limited Slip / 2,900 lb. Rear Axle Capacity // J = Power Steering.
4,800 lbs. Gross Vehicle Weight Rating.
1978
84 = Home Office Reserve (Ford in-house motor pool vehicle, usually driven by employees).
F11YRB31639 / 131 / B / F110 / K81 / Trans A / Axle F9 / 05600 / 172 / 4000 / A77762
F11 = F100 4WD
Y = 352 2V
R = San Jose CA Assembly Plant.
B31639 = 1967, assembled May 1967.
131" Wheelbase.
B = Frost Turquoise (aka Light Aqua).
F110 = F100 4WD, 5,600 lbs. GVWR
A = New Process 435 4 Speed Manual Transmission.
F9 = Not listed, verify if this is the code.
5,600 lbs. Gross Vehicle Weight Rating.
172 net HP @ 4,000 RPM
A77762:
A7 = Ford Motor Company of Canada LTD, Ford Pacific Division.
7762 = Domestic Special Order number. The truck was ordered special by the original purchaser, not "bought off the lot."
Old Aug 13, 2011 | 03:53 PM
429unibody's Avatar
429unibody
Thanks for the info ND
Old Aug 13, 2011 | 04:33 PM
oldblu's Avatar
oldblu
That 78 with the 6 cyl and automatic transmission is THE truck I have been looking for. Do you own it?
Old Aug 13, 2011 | 05:14 PM
429unibody's Avatar
429unibody
It's the tag I took off of the truck I got and it was on a 78 F250 4x4 with a 390 in it. Go figure
Old Aug 13, 2011 | 05:24 PM
NumberDummy
I just returned from an 18 day vacation in the PNW (WA/OR). While "She who must be obeyed" drove, I looked at the scenery, old vehicle scenery...that is.
I stopped counting Dentsides when I got to 131! Most were located in WA, a couple were located on the OR side of the Columbia River Gorge.
So, if you can't find the truck you're looking for...IMO, you aren't looking hard enough.
I also spotted a coupla dozen Slicks, over 50 Bumpsides, a 1965 Mercury pickup in Friday Harbor, and an AC Mack Bulldog in Brewster.
Twisp has dozens of interesting old piles, including a 1956 Ford Cabover Wrecker, and an early 1950's Dodge Wrecker.
Old Aug 13, 2011 | 06:07 PM
oldblu's Avatar
oldblu
There are a ton of old trucks in this part of the country. I just can't find the 6 cyl with an automatic and power steering.
Old Aug 13, 2011 | 09:17 PM
429unibody's Avatar
429unibody
I have a 83 here with a 6 banger and auto with power steering, might be a good donor vehicle!
Old Aug 14, 2011 | 10:54 AM
oldblu's Avatar
oldblu
429,Thanks for the offer. From what I've read on this forum, the ideal donor for my 66 is a 1973-1979. I want to harvest the power steering, disc brakes and the auto trans. I want to stick with the 6 cylinder so I need to find the right donor for the power steering pump, brackets and crank pulley. I haven't done this before so I am trusting the advice of other members on the year range. I don't think too many new truck buyers ordered the 6 cylinder with all of the creature comforts I'm looking for. I've chased a lot of leads only to find something missing. My old truck is definitely a low priority project. I don't drive it too often and it's mostly something to tinker with during the 11 months of gray drizzle we live with every year.
Old Aug 14, 2011 | 11:27 AM
Buzz44's Avatar
Buzz44
Ill keep an eye out over here in the pull and save. Probably will show up there. Multiple ford truck years and options between those years some with ac too. I believe they are on the net too. Might ck and give them a call. They are a division of Spaldings auto dismantlers. Probably one of the biggest in eastern wa.
Old Aug 14, 2011 | 07:56 PM
oldblu's Avatar
oldblu
Buzz, I appreciate the watchful eye. I keep a pretty close eye on Craigslist all around the state. Up in my corner of the state, almost all of the small wreckers are out of business. There's only a couple of big recyclers and they don't keep a thing over 10 years old. I try to take back roads every chance I get to look for old trucks. Thanks again for the help.
Old Jun 7, 2012 | 09:33 AM
429unibody's Avatar
429unibody
F10 = F100 2WD
B = 300 1V I-6.
BA2497 = 1978
133" Wheelbase.
Pickup.
1978
F11 = F100 4WD
Y = 352 2V
131" Wheelbase.
A77762:
F9 = Not listed, verify if this is the code. code was E9
Old Jun 7, 2012 | 06:13 PM
NumberDummy
E9 = Dana 60.3 Rear Axle / 3.54-1 / Limited Slip / 3,600 lb. Rear Axle Capacity.
Old Jun 7, 2012 | 11:04 PM
rogue40's Avatar
rogue40
I know this truck, Friday Harbor is my home town. I blew more than one paycheck in Herbs in my younger life.
Oldblu, Almac by the refineries in Anacortes still deals in old iron and they don't pull the motors so there is a good chance of finding an intact ac unit.
They were the only ones who had a decent '76 donor for my disc upgrade.
Old Jun 7, 2012 | 11:45 PM
429unibody's Avatar
429unibody
Thanks for that update ND
bigmark
Large Truck
Apr 13, 2016 09:21 PM
muddhogg
Jun 29, 2009 10:03 AM
f100dw
Jan 7, 2003 05:02 PM
F100DREAM
Jan 2, 2003 11:23 AM
Kid
Mar 24, 2000 02:47 PM
