351windsor questions
Old Jul 18, 2011 | 09:57 PM
KawiRider78's Avatar
KawiRider78
i was wander what the specs are on a 85 351 windsor about how much hp and tourqe and all so i was wandering if the single belt pulley brackets off a 302 will fit the 351 w thanks
Old Jul 18, 2011 | 10:02 PM
glovemeister's Avatar
glovemeister
190 and 285 roughly...
Old Jul 19, 2011 | 09:30 AM
Franklin2's Avatar
Franklin2
If the bracket bolts just to the head or just to the block/waterpump, it will probably work. If the bracket bolts to both the head and the block it usually won't, since the block is taller and the heads are farther apart than on a 302. They do use the same waterpumps and heads, but they are in different positions.
