Hey everyone. I just wanted your opinions to see if I am thinking right here....
This weekend I took my new 6.7 to WV to ride UTV's. Well my truck has done awesome on fuel mileage but this weekend it did horrible. Well I feel it did horrible.
I was towing a 1500 pound trailer with my 1400 pound Can Am Commander UTV. It seemed like it was just a drinking the fuel. I did not use tow haul. I figured it was such a light load for this truck.
Should I of set it back to 5th gear for the whole trip?? Was that 6th gear causing the motor to bog down? My old 6.0 was a 4.10 gear and ran about 2200 to 2500 rpm's up the hill and I feel did way better. This truck was running 1700 rpm's in 6th with the 3.55 gear. If I drop it to 5th it went to 2100 rpm's.
This light load never hurt my fuel mileage on my 6.0 but on this 6.7 it did cause it to drop to 14mpg on a truck that was doing 19. I say my 6.0 didnt get hurt on fuel because it was doing bad at around 12 to 13 PERIOD and was running 2300 rpm's all the time in its top gear of 5th gear.
Also to consider this new tank is smaller than my 6.0. My 6.0 was a 28 or 29 gallon I think and this new one is 24.
I think the truck is doing half was ok on fuel......should I run it in 5th all the time when towing??
Tank in a sb is same size I think. Head wind? Tire pressures? U probably should a been in T/H in my opinion, locking the TC gets
Ess slip and better mileage.
Okay, so you're getting 14 towing when your 6.0 was getting 12?
Couple of questions:
How fast were you towing?
What were the conditions; head wind? up hill?
Towing my 8K tt, I get about 12-14 if, and only if, I keep the speed below 65.
The tow/haul mode (according to the book in the glove compartment) is more for the engine braking mode and pulling heavy loads in hills. The manual does say the normal mode will get you better fuel economy.
These things are torque monsters, you don't need to be generating a lot of rpms to make torque needed for towing. Just put 'er in 'D', set the cruise at 63 and be happy!
If you have the cc sb, your tank is a 26. That's what I have and I also feel it is small. My '00 had a 32 gal tank and at times, that was a bit small. I carry a 5 gal gerry can when I'm towing. Just in case . If you really hate the small tank, Titan and Transfer-Flow both make after market tanks that are around 50 gal.
14 Mpg at 75mph sounds right to me. also did you test the MPG with the gage or deviding miles by gallons used?? Also I beleive 75 mph is more like 77-78.
Guys I really think I am not used to the smaller tank. I have had two DRW trucks in the past and now I have a SRW short bed 250. I think I am not used to that tank AT ALL is my problem. I just wanted to see if I was thinking right.
I think you mean 77-78 is more like 75. Most of my speedometers over the years have been 2-3 mph off on the high side. We have multiple speed limit signs in my area with built-in radar and indicators, so I check mine a lot. I also had a cop buddy of mine check my 6.7 with his laser - speedometer says I'm doing 68 when I'm really doing 65 (he used the laser on his F-150 as well - off high by 3 mph). Wife's Honda is also 3 mph on the high side.
2-3 MPH is what I'm noticing also.
The truck does know what speed you are going but doesn't display it properly with the gauge.
Put the screen into engineering mode and find the speed option and you'll notice what I'm talking about.
I tend to drive 5 over so I feel I'm safe enough.
If DOT wants to give me a ticket for 1-2 MPH over, more power to them.
I depend on my GPS if I need to be exact.
Both my topo and street GPS are similar within a few tenths of a MPH.
so do u guys think that I should run it in 5th all the time or just put it in D and let it be. Shift when it wants?
There is absolutely no cause here to lock out 6th gear in this case, as the truck easily has the power to pull that load in 6th.
When I towed my enclosed car hauler at 10K lbs I never ever locked out any gears. This is a feature that's supposed to get used when the truck doesn't have enough power to pull the load in the top gear, and it will prevent the transmission from hunting between gears. There should be no gear hunting with 3,000 lbs behind you.
Try towing the same load at 62-65. Aerodynamic drag increases exponentially as speed increases. That's the enemy when trying to make MPG.
I can tow my fiver (11,000 pounds +) in 6th up many hills at 62-65 and still make 12+ MPG unless there is wind in my face. If I bump it up to 70 I'll lose at least 1 MPG.
The pure aerodynamic drag effect is the exact square of the velocity. It takes exactly 4 times the energy to overcome the air resistance at twice the speed. But you also have to take into consideration all the other elements in the system including Newton's first law. They all combine to require, as Ziff mentioned, exponentially more energy to step up the speed even a little.
Wow sorry but we are spending way to much time on this issue. 1st. Leave the truck in Drive 2nd you don't need to use tow hall on a load that light 3rd only use the miles driven by gallons used method to get an accurate fuel millage reading( you will need to fill up before and after your trip) 4th 14 Mpg is totally plausible depending on how you drive and the terrain your driving how many people in the truck,Topper ?, wind, outside temp, etc.also keep in mind the Speedo is off a bit with now way to correct so you will not be 100% accurate anyway
