I just had e4od rebuilt for my 92 F-250 Builder recommended cooler said I should bypass cooler in radiator. Had him get me one but to me it does'nt look big enough to install that way. Its only a 10,000 lb hayden Would appreciate any input or suggestions. first exp with e40d
Was this a catastrophic failure of the trans..........
Was it just a rebuild or upgraded too........
So the rad has been taken out of the loop......
What is the largest items you tow...... any idea on a CGVW truck and ??
Put up some truck and location info in a signature.......
Without the lower rad in the system you loose the heating/cooling effect of your fluid...... but if you operate in warm weather only that would be ok.
IE.... I live where it gets -40F so when I start the engine it heats up and then warms the trans fluid going through the base of the rad.......
If the cooler in the rad has been contaminated, get a can of cooler flush, flush it one way, then back flush it, and flush the lines also. Then in the return line put a magnetic filter to catch any fine particles that are left.
trans would not go in forward gears just rev. truck is a 92 f-250 4x4 7.3 not looking to do alot of towing but will be hauling camper and towing small trlr for my bike. But with that said would still like to be set up to tow heavier trlr if need to. I live in washington so do have alot of hills and mountin passes. thanks for the replys
Thanks for reply Will be putting new 3/8 lines on and going with synthetic fluid after running reg fluid to flush any particals that may be present after having trans opened up. Also thinking about adding remote filter . Just want to do this right first time any advise i can get is greatly appriciated!!!
Install the remote filter in return line at rear of transmission.
You need to have the cooler in your rad also, the water is more effective at cooling then air, and in cold weather it warms the fluid, without that cooler I'm doubting you will have enough capacity. Just flush the cooler with cooler flush and the magnetic filter is a must, the warranty on my trans depended on it, the magnet will catch any metallic material stuck in the cooler and any material that is created with use.
Thanks for tip where do I find a magnetic filter???
Ditto on running both coolers. I don't have an E4OD but rather a C6 so I don't have the locking TC so my oil temps would be higher than an E4OD. fluid temp in the pan with both coolers (10kgvw cooler added on) now is about 190* when towing about 7k lbs in 90 degree weather.
Thats what I was thinking as soon as I saw the size of the cooler ,did'nt think about needing to warm fluid in winter. Will clean rad cooler and add remote filter to system with 3/8 lines should help with fluid flow problems I have read about. Also need to change rear main seal while trans is out. Will sure be glad when its back together.
after 3rd gear,the convertor locks up,which drastically lowers the temps compared to when open/the old C6.an external filter doesn't need to be large.it just needs to be efficient.
im not a fan of bypassing the stock rad,warmer/cooler.but instead i installed my external after it,along with an external filter.
you should consider installing a temp gauge,which you didn't mention.
now would also be a very good time to install a shift kit as well.
here's my (stock,of course.im still under 75k orig miles) E40D setup:
B&M SuperCooler Transmission Cooler #70268
B&M Universal Remote Transmission Filter Kit #80277
B&M Light Truck Shift Improver Kit #10025 - Installed STAGE 1. HEAVY DUTY
Cyberdyne Digital Transmission Temp Gauge -Red Heat/Black Bezel/Memory w/Sending unit #A221E061Y
i have my sending unit measuring the actual fluid temp just before it enters the radiator and external cooler,and at most i see is 200 degree's in traffic,or when plowing (i stop plowing when it hits 200,because i don't have an e-fan on it.)
here,the temps can go much higher than 200,unlike @ the pan.but i like my juice to last,so i don't need to flush it every 15k.
it's most common to read around 160-170 99% of the time.
