Brake Contoller Problem
Old Mar 30, 2003 | 07:28 AM
sparkeyone's Avatar
sparkeyone
I have an '89 F-350 I bought it used a few years back. I noticed awhile ago that the emergency flashers actvate the brakes on the trailer. Yesterday I installed a new controller (the old one came apart) I noticed whoever installed the old one had hooked up the cold side of the stop switch at the brake light switch on the pedal arm. I installed it as per the instructions, on the c shaped connector second wire (light green) on the top row of seven. I had hoped this would solve my problem, but to no avail... it still does the same thing. I would appreciate any suggestions.
Old Mar 30, 2003 | 11:14 AM
steve83's Avatar
steve83
The hazard circuit turns on the brake lights, just like the brake switch, so that's a characteristic of all electrically-activated controllers. If you go to an inertia or hydraulic controller, it'll quit.
Old Mar 30, 2003 | 01:11 PM
sparkeyone's Avatar
sparkeyone
I have the same controller on my '97 Expedition & '02 F-150 and I don't have that problem with either one of them.
Old Mar 30, 2003 | 02:48 PM
steve83's Avatar
steve83
But on those trucks, the hazards use the turn signals which are independent of the brake lights.
Old Mar 31, 2003 | 01:09 AM
charlez's Avatar
charlez
Yup, my Prodigy in my 93 does the same thing, need to remedy that somhow...
Old Apr 1, 2003 | 12:10 PM
crustydoughboy's Avatar
crustydoughboy
Unhappy Brake Contoller Problem
this dosen't cause much of a problem along the side of the road, BUT when pulling up a grade and going slow, DON'T put on the em flashers like some do. it would be like pumping your brakes while giving it the gas.
:-staun
Old Apr 8, 2003 | 09:25 PM
FiremanRon's Avatar
FiremanRon
Tekonsha (and probably others) makes an Isolator for this very problem. I'm not sure what it costs, likely not much. It is on their website. www.tekonsha.com
Old Apr 8, 2003 | 10:04 PM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Welcome to the Towing forum, FiremanRon!
Thanks for posting the link! I found the part you are refering to, it's called a 'pulse preventer'.
Scott
