Compression ratio
Old Mar 30, 2003 | 01:24 AM
lifeworks@dmv's Avatar
lifeworks@dmv
Compression ratio
Just purchased a 1993 F-150 w/<a href="http://www.motorhaven.com/">302 </a>short block. What is the compression ratio required?
May have to replace engine due to bad #7 cylinder.
Old Mar 30, 2003 | 08:50 AM
mantta's Avatar
mantta
Compression ratio
I think you mean, how much compression pressure should you have. The answer is that the lowest pressure you get must be at least 75% of the highest reading you get to be acceptable. This is from the Ford F Series Specifications Book. Other manuals will say if it is 20% below the pressure of the other cylinders.
Old Mar 30, 2003 | 08:10 PM
mrak's Avatar
mrak
Compression ratio
Just turning over the engine cold, with out opening up the throttle and things needed for a proper compression check I was getting in the 120-150 lb range on my 1994 with 105k miles.
IsoGrifo
Oct 16, 2009 06:37 PM
390
Oct 19, 2008 12:58 AM
mark460
Jun 8, 2007 09:16 AM
fordtruckin
Apr 13, 2002 10:12 AM
