Coolant Flush
Old Jul 14, 2011 | 12:32 PM
hp325's Avatar
hp325
Coolant Flush
I've read alot on here about coolant flushes. So I bought a gallon of Restore and 2 qts of VC-9. My question is which do I use first or do I put both of them in at the same time? When I get that done I got a modified intake from Doug at Go Go Diesel which will get rid of the EGR system altogether. Also changing out the oil cooler and putting in the blue fuel pressure spring, and installing a CFM intake elbow. I know I got my work cut out for me. Thanks for any help
Old Jul 14, 2011 | 12:42 PM
rocky1074's Avatar
rocky1074
Don't put them in at the same time. I would do the restore first. I would use tap water first than when it comes to the final flushes I would use distilled water.
Old Jul 14, 2011 | 12:44 PM
BLADE35's Avatar
BLADE35
run the cleaners separate after you get the coolant oout
you may want to just keep the stock intake manafold even with an egr deleate you still need egr valve plugged in for fan operation
good luck be carfule with those turbo bolts best to break free with a 6pt box wrench
Old Jul 14, 2011 | 05:41 PM
69cj's Avatar
69cj
Keep the stock intake. Your truck will be happier and thank you for it.
Old Jul 18, 2011 | 07:01 PM
hp325's Avatar
hp325
Got the flush done. Starting to dismantle things. How much of the fan shroud has to come off? I see there are some bolts where it is fastened to the intake.
Old Jul 18, 2011 | 07:05 PM
BLADE35's Avatar
BLADE35
I just undid the top peice of the fan shroud real easy just separate with a screwdriver at the tabs
you will need to separate the elbow where the cac tubes 90* down into the intake manafold from the manafold itself this is for that stud that does from intake to fan shroud
oh ya IIRC those other 2 bolts were 15mm the ones you can see the heads
but other than the top peice of the fan shroud you just need to undo the bolts but the plastic shroud stays inplace
Eallend7
Mar 6, 2013 07:27 PM
olfordsnstone
Feb 28, 2013 08:33 PM
Diesel cat
Feb 1, 2012 07:23 AM
Subi69
Jul 28, 2011 11:50 PM
doug70
Mar 19, 2010 09:59 AM
