Pictures by 19frankentruck78 - Photobucket
Here are some pictures lots of parts still left
black running boards no lights $100/pr
6.0 heads $400/pr
Chrome grill missing right insert and small chip in right side $45
dutch doors $65/ea
2nd row seats $250/pr
3rd row seat $200
I need that left insert from your cracked grill. Also need the two rubber grommets inside gas cap. I can PAYPAL you $25 if you are interested. Gonna look over my 2004 Excursion to see if there is anything else I need.
The center section is removable but with as delicate as the plastic clips look the only way I would attempt to remove it would be to cut the other side off making the chrome part garbage. The only advantage would be a smaller piece to ship and I'm sure that would cost a lot less. So same price but I would need a little time to remove it
Thanks, Doug
Originally Posted by rbrad6937
I actually only need the center insert. Is that removable? If so, how much?
