Solid Front axle
Old 07-13-2011, 06:08 PM
musclecars90's Avatar
musclecars90
musclecars90 is offline
Solid Front axle
I got a 1990 f-250 doing a frame swap to a 89 rolling chassis. Since everything is easy to get to I would like to do a solid front axle swap. A buddy of mine has a early 80's f-350 will the solid front axle from that bolt right up? If not what would have to be done.
Thanks
Old 07-14-2011, 06:51 AM
Lazy K's Avatar
Lazy K
Lazy K is offline
I would think it would. Click the search button and enter "sas" in the box and click search and you will get a ton of info.
Old 07-14-2011, 09:14 AM
dclack's Avatar
dclack
dclack is offline
No it won't bolt up. You need an axle from a '85.5 to '97 F350. You could probably get it to fit with a little fab work though.
Gear619
05-30-2014 06:25 AM
rampus
03-14-2011 01:01 AM
SD Diesel
04-23-2008 03:43 AM
dougpfaff
02-18-2008 07:42 PM
Quick Reply: Solid Front axle
