Thermostat
Old Jul 13, 2011 | 09:04 AM
Rick2001's Avatar
Rick2001
Thermostat
Which one is best?
What temp range?
I am currently using the 203* stat but I see there is a 180* that claims thats the best way to go?????
Old Jul 13, 2011 | 09:36 AM
jwhitetail's Avatar
jwhitetail
The motor fires from heat combustion 203 is better than 180. IH motors run a 203, thats what they recommend, Ford engineers put 195 stat in our 7.3's that's what comes from the factory. leave the 203 in. JMOP.
Old Jul 13, 2011 | 09:47 AM
nlemerise's Avatar
nlemerise
OK folks, just take one...there is plenty of popcorn for everyone!
I actually concur with jwhitetail...but this is always a fun topic...a lot like "What is the best oil?" thread. What is the reasoning for the claim of the 180 degree t-stat being the way to go?
Old Jul 13, 2011 | 09:52 AM
Rick2001's Avatar
Rick2001
dang I can not remember their full claim, if I find where I saw it (it was months ago) Ill add it to the thread
Old Jul 13, 2011 | 10:00 AM
mueckster's Avatar
mueckster
Here ya go. 180 Degree T-Stat
I actually ran the 203* t-stat for several yrs then went back to the 195* for a couple due to slightly elevated temps. Thermostats don't always last forever. I currently have a 203* t-stat and DS billet housing now. I saw a loss in mpgs with the 195* and regained it with the 203*. I am seeing EOT's that are in the normal range so I'm leaving well enough alone.
Old Jul 13, 2011 | 10:06 AM
Rick2001's Avatar
Rick2001
Yep that was it! Thanks.
Grabbing a box of popcorn.....
So what do we think? Probably splitting hairs for a stock to mildly modified truck? Maybe of some benifit on a heavily modifed truck?
Old Jul 13, 2011 | 10:12 AM
mueckster's Avatar
mueckster
Those are my thoughts too. All I know from real world experience that my truck "likes" the 203* better.
Old Jul 13, 2011 | 10:34 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Wat you doing on here at this time?
Old Jul 13, 2011 | 01:54 PM
DieselHardware's Avatar
DieselHardware
The 180* Tstat was developed for the guys running the aftermarket oil systems. Since the aftermarket oil systems flow more oil than stock, the oil is being circulated more often and at higher pressures than stock. This brings the oil temperature up. With twin HPOPs it isn't unheard of to see EOTs in the 215-225* range. Personally with an ambient of 115*+, I have seen EOTs as high as 228*. If you put in a lower temp Tstat and lower the coolant temp, you're also helping to bring those EOTs down since the oil is cooled by the coolant.
Old Jul 13, 2011 | 02:26 PM
helifixer's Avatar
helifixer
my 203 stuck last week, took it out and out the 180 in. trip to Tucson and back my mileage was down 2 mpg.
Old Jul 13, 2011 | 04:02 PM
nlemerise's Avatar
nlemerise
Maybe there is something I am missing here, so help me. ..My understanding of a coolant thermostat is that it simply regulates the temperature at which coolant begins to be passed from the engine to the cooling system components capable of shedding heat (radiator and heater core). So a 180 thermostat opens at 180 degrees, while a 203 opens at 203 degrees, etc. etc. The thermostat (in my thinking) has almost no control on the upper range of coolant temperature, only the start of flow to the radiator. I guess what I am saying is that two identical 7.3l diesels running down the interstate next to each other, one with a 180 thermostat and one with a 203 thermostat, would have the same coolant temperatures (after an hour or so). The only things that controls upper temperature of coolant are the size of radiator, size of water pump, size of fan and how fast this system can shed heat to the atmosphere. How does having a lower temperature thermostat "lower the coolant temp" and "bring down EOT's? I am not saying this to be argumentative, but to learn...I'm at my desk ready and all ears!
Old Jul 13, 2011 | 05:48 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
I think the situation you describe would occur only if there was no thermostat. The thermostat starts opening at the rated temp, but only a bit. This allows some hot coolant out and cool coolant in. If the temps rise it opens a bit more, if the temps fall it closes a bit to constrict flow. This regulation of the flow of coolant balances at the rated temp.
Anybody else getting better mpgs with the 203*? I blew that off as codswallop... but mpgs are gooood!
Old Jul 13, 2011 | 09:53 PM
DieselHardware
What he said....
For some reason I always seem to confuse myself when I try to explain it. The biggest thing is a bunch of guys I know running the twin HPOPs have EOTs that are in the 200-215* range. With the 180* tstat versus the stock tstat, their EOTs are in the 190-205 range. I know it works. I just relocated my IPR dump for my pumps and that has made a difference around town, but haven't had a chance to see what it does on long drives. After I get that data, I will be putting the 180* tstat in.
Old Jul 13, 2011 | 10:09 PM
mueckster's Avatar
mueckster
With my Stealth Stage 1 HPOP (equivalent flow of 1.5 stock hpops) and the 203* stat, I generally see ~200* EOT on a 95-100* day. I have seen a max of 207* when running slow or ******* it with the a/c due to the added condenser heating. My temps with 203* are right inline with those running the 180* stat and dual pumps.
Old Jul 13, 2011 | 10:19 PM
clux's Avatar
clux
Rated temperature is the temp at which the thermostat is fully open. Per Bob Reiley, 203* is the temperature at which his thermostat is fully open.
I got +1.5-2 mpg just like Roland, there won't be a cooler one back on my engine ever.
Thanks for the popcorn, Neal.
