a/c issue...need advice.
Old Jul 10, 2011 | 08:08 PM
2003u45's Avatar
2003u45
this was perfromed at a shop and now they are stumped. my compressor dook a dump. replaced with dryer and all schrader valves. added dye and no leaks. works ok under load (moving with gas pedal) temperature increases in b2b traffic and also when not on gas pedal. perfromance testing the compressor in the shop, all works fine, pressures are where they should be. get out on road, not so much. upset the wife on an hourt long trip today once we hit some traffic.
the compressor we used was identical to ford unit but wasnt Ford brand from Ford dealer. But this unit does NOT put out the cool air like old unit did. Still humid in vehicle also but air is cold when driving.
any ideas or experience with this issue? thanks for your input.
Old Jul 11, 2011 | 06:08 PM
Sader's Avatar
Sader
Did they verify the new compressor has the same performance specifications and the old one? Maybe you need an orifice tube (front) or a TXV (rear)? Not moving enough air across the condenser? (Fan Clutch and/or fan)
Old Jul 12, 2011 | 07:29 PM
2003u45's Avatar
2003u45
fan clutch is good. orifice tube replaced. not sure about txv but the rear expansion valve has been replaced. what the heck is the txv?
Old Jul 12, 2011 | 08:14 PM
Sader's Avatar
Sader
TXV = Thermal Expansion Valve.
Hmm, Are the pressures good at idle? Any idea what they are?
2003SuperDuty7.3
Electrical Systems/Wiring
Aug 15, 2014 02:06 PM
familiar1985
Garage & Workshop
Jul 12, 2010 04:30 PM
rschleicher
Sep 12, 2008 09:18 PM
4doorsuper
Aug 15, 2005 05:35 PM
Tekrep
Jan 16, 2004 08:40 AM
