front wheel "death" shake
Old Jul 10, 2011 | 10:25 PM
earthquake68's Avatar
earthquake68
Originally Posted by bamaf150
Trac bar bushings helped mine alot, also they say these frames are prone to cracking behind the steering gear. Earthquake, how do you check with a prybar? Put front end on stands and try to pry on tires?
Jack up the axle (or the control arm) as close to the wheel as possible without touching the tire. Have someone look at the ball joints while you slip a bar under the tire and pull up on it. On a strut car, you let the tires droop and jack up on the frame/body.
So yeah, you were right. I just wanted to be clear.
Glad you found it. I parked my truck for a couple days when I hit a bump and the truck jumped into on-coming traffic. After I dug the seat cover out of my butt, I ordered the parts I needed. Loose front ends are no fun at all.
Old Jul 10, 2011 | 10:38 PM
BACRAKR's Avatar
BACRAKR
Thats what i get for not reading.
2008F250SHAKING
Dec 28, 2015 12:12 PM
1Austin112
Jun 13, 2015 11:49 AM
Rob_82
Mar 25, 2015 11:34 PM
BenFranklin
Nov 4, 2014 07:43 PM
BlackNGoldRules
1983 - 2012 Ranger & B-Series
Aug 9, 2010 07:14 PM
