Help a gal with her '76 F-250 clutch
Greetings!
I have been under my pickup for the last half hour trying to figure out where the other end of my retracting spring is supposed to go. I get how the clutch lever/release rod/spring end go together. The original retracting spring broke last week and I got the part today. Everything else looks fine with the clutch pedal and assembly.
I have the Chilton book but it only shows the placement for the '78-80 and I have run my fingers over every surface and chassis area withing a reasonable spring-reaching range. I've also googled every combination I can think of to get a better diagram for this thing. HELP! Where the *bleep* does the end of the spring go?!! :-)
Thanks so much!
--erica--
Thanks so much!
--erica--
Thank you!
Holy crap--those are great photos. Thanks so much you two. I'm wondering if that L bracket actually came unbolted or fell off or something. I was roaming around shining my flashlight up and couldn't find it. The retracting spring actually seemed to break just after I parked in my driveway (small blessings) because I found the old part and subsequently the release rod extension under the truck. Can't find that L bracket on the ground, though. Mystery? I'll start fresh with the sunshine tomorrow, especially now that I have those pics.
Thanks again!
Thanks again!
Still no luck
So, I found a medium sized hole in the chassis (and a pin hole in my oil pan, actually, which explains how filthy the undercarriage is *sad face*) where I imagine that L bracket might be but the spring now looks 1/8-ish" too long for it to actually go there but the new spring matches the old spring size so I'm sure my part is correct. I still can't find any L Bracket under the truck/in-the-driveway that may have come off, nor does it seem like there's a place where an L bracket might have been, really.
When I drew my fingers around that medium sized hole, I found neither bolt nor screw laying on the other side to indicate one half may have fallen off. Further, the hole is just as oily and greasy as everything else which would indicate to me that nothing has occupied that hole for quite some time, if ever. This clutch spring only broke a week and a half ago.
Thanks again for all your help. I may need someone who actually knows what they're doing to come find this freakin' hole/L bracket for me. I mean, I'm no mechanic but you'd think I could put a spring back on... geez.
Of course Burburan, i would do anything for a fellow Ford lover even if that includes going back in time to answer their questions!
Lol but no, i go through a lot of batteries with the dang camera so that i dont keep batteries in it anymore, i just put them in when i need to use it and i dont set the time and date anymore lol. But im glad to hear you were able to get some use out of this thread too .
