coolant swap
Old Jul 10, 2011 | 05:00 PM
CPUNeck's Avatar
CPUNeck
Originally Posted by Deluxe06
I went to Heavy duty CAT ELC, It's been probably about 6 maybe 7 months now.
Me too, I used the Fleetrite ELC flavor (its Red), did the swap in 03-04?? Can't remember, I have a filter and it still looks brand new. I have an early bird, and no adverse effects. Bout time I had some luck.
So are all the replacement cups the upgraded material so if you change them you'll be G2G? Injectors are on my horizon, and I might just do this too.
Old Jul 10, 2011 | 08:12 PM
429 f-100's Avatar
429 f-100
So are all the replacement cups the upgraded material so if you change them you'll be G2G? (( Injectors are on my horizon,)) and I might just do this too.[/QUOTE]
mine to but i saw all the horror stories of cups becoming loose and other gaskets and the holes in the frt engine cover. hard enough to keep up with all maintenance stuff as it is im not trying to make anymore.
Richard isn't yours a 2000 ?
Old Jul 10, 2011 | 08:16 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Richard isn't yours a 2000 ?[/quote]
Yep................
Old Jul 10, 2011 | 08:30 PM
429 f-100's Avatar
429 f-100
Yep................[/QUOTE]
so your motor is fine on elc. unlike mine
Old Jul 10, 2011 | 08:42 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Oh crap!! I guess so. But I don't see where you would have done any damage in 12k miles. It's not like putting 50k to 100k on it.
Old Jul 10, 2011 | 11:34 PM
SpringerPop's Avatar
SpringerPop
The problem isn't the injector cup material, it's the injector cup SEALANT material that is adversely affected by the ELC.
The PowerStroke injector cups are all brass, regardless of the year.
When they are installed into the cast iron heads, they are pressed in while using a sealant on the outside of them, to seal between the brass and the cast head. That's the sealant that is different pre- and post- 99.5.
Inside the cups, where the injectors are, they are sealed by o-rings, and have no other sealant.
Pop
bakos
Jan 4, 2015 07:48 PM
hink10
Nov 25, 2012 11:38 PM
durnan
Jun 26, 2003 07:44 PM
