Hey Ken,
Will the <a href="http://www.motorhaven.com/">Diablo</a> Delta chip provide the bump in transmission pressures for firmer shifts in the 87 program. If not can these be programmed into it?
Also, have you had good luck with providing a custom program for headers/Powerpack?
No, I need the 4 digit ECU code. Its on the computer box, on the wiring harness that connects to the computer, driver's side door frame next to the hinges and on the computer box where the wiring harness connects to it. Between all those, you ought to be able to locate it.
YU7A-12A650-BYA is the only reference I have on the new code. No 4 character code was given. Any idea how I can obtain the new code from this reference?
