pulling the motor
Old Jul 8, 2011 | 09:57 PM
jdmcivic23's Avatar
jdmcivic23
pulling the motor
hey guyz i have a 94 f150 with a 302 v8 need to pull how hard is it to do can anyone help me out please.
Old Jul 9, 2011 | 09:24 AM
Conanski's Avatar
Conanski
It's not hard work but it could take a whole day to complete depending how friendly you are with tools. You need a hoist obviously and a selection of sockets and extensions, you will have to drain the coolant and remove the rad, remove the upper intake and disconnect all the wiring and cables, disconnect the transmission and torque converter, and also disconnect the exhaust which could be the hardest part because of corroded bolts. I'd also suggest removing the accessories and brackets from the front of the motor, and then with the engine mounts disconnected it's relatively easy to pull the motor off the trans and hoist it out of the engine bay.
Old Jul 9, 2011 | 11:13 AM
jroehl's Avatar
jroehl
An engine hoist is an excellent tool for testing the tensile strength of any wires and hoses that you forgot to disconnect...
Jason
mudslingur
Offroad & 4x4
32
Jan 14, 2007 06:31 PM
385seriesHemi
Minnesota Chapter
17
Oct 8, 2006 04:04 PM
nostarttireflat
Mar 19, 2004 10:38 PM
sb2371
Paint & Bodywork
Jul 3, 2002 05:03 PM
Jaseun
May 11, 2002 11:50 PM
