Rear end question?
Old Jul 8, 2011 | 06:41 PM
Machinegunmike's Avatar
Machinegunmike
Rear end question?
Wondering how I can tell what kind of rear end is in my 64 f100 with a 292 4speed on the floor all original and what ratio?
Old Jul 8, 2011 | 08:01 PM
99hosss's Avatar
99hosss
It'll have it stamped on the pass.side of the rear axle, Least that's where I found mine and mabey attached to a tag on a bolt. Also look at your tag on driver door by the latch
Old Jul 9, 2011 | 02:04 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1964 F100: Ford 9" rear axle standard equipment / Dana 44 with Limited Slip an option / Dana 60.2 with Limited Slip an option.
The 9" does not have an inspection cover, the Dana's do.
The Warranty Plate is located on the left door face below the latch: Warranty Plate AXLE code: If it begins with a letter: Limited Slip. If with a number, no Limited Slip.
Ford 9" rear axle tag will be located under one of the bolts (at circa 5 o'clock) that retains the carrier to the housing.
The Dana axle ID tag is under one of the bolts that retain the inspection cover to the housing.
Do not be surprised if these tags are missing by now.
Old Jul 9, 2011 | 06:24 AM
Machinegunmike
Thanks fellas for the info I know now that I have a ford 9", is that cheaper to find highway gears for than the Dana rears?
Old Jul 9, 2011 | 07:51 AM
NumberDummy
1957/79 Passenger Car 9" R&P's interchange, but there's a lot more ratios to choose from. Example: How about a 2.47-1 from a 1978 LTD?
Dana R&P's, if any can be found, won't be cheap.
