6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Correct voltage output
Old Jul 8, 2011 | 03:35 PM
Leonandlisa's Avatar
Leonandlisa
I have the edge insight cts gauge on my truck to watch everything. For the first year it was always at 13.9 - 14.1 while it was running. In the last month it is running at 13.3 -13.6, and it doesn't matter if the lights are on or not. The reason I question this is because the last month if the truck sits for more then two or three days the batteries die. The batteries are exactly a year old and I just took them to be tested and they are both over 85%. Can an alternator partially fail? Or not produce enough voltage to properly charge the batteries?
Leon
Old Jul 8, 2011 | 07:29 PM
senix's Avatar
senix
The way to test the charging system is usually with the truck running. Then command max alt output and see what you get.
Old Jul 8, 2011 | 09:24 PM
Tom's Avatar
Tom
I don't have access to the shop manual for this truck, but for my other Ford car the spec is 13.0-15.0 V alternator output voltage.
I think you're fine. I agree with Scott: Start the truck, turn on everything electrical at their highest setting such as blower motor, heated mirrors, lights, etc. and check voltage. If you're above 13 it's charging fine.
Old Jul 8, 2011 | 10:12 PM
Leonandlisa
Thanks for the help guys, I will give it a try.
Leon
Old Jul 8, 2011 | 10:17 PM
StanleyZ's Avatar
StanleyZ
Yeah, I have an Edge and mine runs 13.5 most of the time, but the batteries should not die in 2 or 3 days. Are you saying they will not start the truck after sitting for 2 or 3 days? If so, you either have bad batteries or an eletrical drain when the truck is turned off. If you start the truck and run the reset check on the message board what does it say about the "charging system"? Maybe that will givfe you a clue.
Millinex
Apr 9, 2017 11:53 PM
Brown Falcon
Aug 19, 2016 11:24 AM
fireman660r
May 3, 2016 04:23 PM
zeus77
Jun 8, 2012 03:28 PM
schuster66
Escape & Escape Hybrid
Apr 22, 2012 10:57 PM
