I am working on an engine rebuild. It's a 351W. One of the things I am changing is I am using timing gears instead of the stock timing chain. I have two questions about this:
First, if anyone has done this before on their engine, I'd like to know if you had troubles with the timing cover. When I put on the stock timing cover, it won't go on because there is a piece of metal in the middle of the cover that hits the gears in the middle (the driver gears) - http://imageshack.us/photo/my-images...blockblue.jpg/. If I was using a timing chain this piece of metal would fit in between the cam and crank sprocket. So I am not sure if I can just take off the metal that is in the way on the cover or if I need to get a new one. Anyone?
Second, this brings up the question of timing and what I should think of setting the truck to. I know what timing is but not sure if I should install the crank sprocket at TDB, BTDC, or ATDC. When installing the sprocket I can go at either ) degrees, +2 degrees or - 2 degrees. So I am really looking to learn what questions I should be asking myself so that I can determine what will be best.
Thanks.
Reason: 'cuz
Could you post up a pic of the inside of the timing cover so we can see what part is hitting the gears?
As far as cam timing goes, what cam are you running? Advancing the cam will usually increase low-rpm torque at the expense of high-rpm power and vice versa.
I can post a pic of the timing cover tomorrow.
As for the cam, it is a custom grind, here are the specs:
Whoever designed your cam will tell you what it should be set to. You spent good money for a custom fit piece, follow their recommendations. It appears the cam is ground with 4 degrees advance built into it. I suspect you need to install it "straight up".
Yup. Agreed.
Originally Posted by deeznuts822
maybe he is talking about the fuel pump cam,If so you dont need it unless you are running a carb.
It's pretty obvious that the OP (and the rest) are talking about the camshaft here.
i cant see that piece causing any problems removed, and if you ever go back to a chain, just pick up a cover from a bone yard, or a new one for 85 bucks from summit
I am no help to the OP but want to say nice.... Love the block paint~
Thanks, I did take time to make sure it came out good. 3 coats of primer and the same for the color, per the instructions. I switched from the original Ford blue which was lighter.
I called Edelbrock (who makes the timing gear set), they said I can cut that piece off. Now I just gotta figure out how much to cut because this piece can also hold the gears in place.
I took out that piece from the timing cover and it would work if I wanted to bolt it on but I think there should be a little more clearance so I am going to buy a new timing cover and see how that works.
