Decode Vibration Dampener Casting #
Old Jul 7, 2011 | 10:54 PM
TxF100's Avatar
TxF100
I have a vibration Dampener that I am needing to decode. Is there a place to decode Ford part #s? The casting # is COAE-6316-A
Thanks
Old Jul 7, 2011 | 11:36 PM
Old F1's Avatar
Old F1
The experts say that you cannot decode casting numbers into part numbers but do we care, even if not really exact.
Around a 1960 car, if that helps, would need a parts book that I don’t have to maybe tell engine size.
Old Jul 8, 2011 | 10:58 PM
TxF100's Avatar
TxF100
I was trying to see if it was a Y-Block part # or an FE
Old Jul 8, 2011 | 11:22 PM
Old F1's Avatar
Old F1
Hum, I think I will have to leave you in the caring and gentle hands of “number dummy” retired ford parts-man extraordinaire. Best to send him a PM with all the info you have and a precise question.
Old Jul 14, 2011 | 06:57 PM
TxF100's Avatar
TxF100
I checked the Damper Doctor and the ECG 6316 D1 that was cast on it, was for 292 Y block. Thanks
Old Jul 14, 2011 | 08:29 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Old F1
The experts say that you cannot decode casting numbers into part numbers.
But, this is not a casting number...it's an ID engineering number which can be cross referenced to a Ford part number.
COAE-6316-A = COAZ-6312-A .. 292 Harmonic Balancer-Single Sheave.
Applications: 1960/62 Ford Custom/Galaxie.
Old Jul 16, 2011 | 08:50 PM
TxF100's Avatar
TxF100
Thanks for the info. Looks like all references are pointing that this will work on my 57 292.
Old Jul 17, 2011 | 06:21 AM
NumberDummy
What references might those be?
You have to match the harmonic balancer to the existing flywheel your engine has now. Otherwise you will have a vibration that sooner or later, will tear the center from the flywheel.
The COAZ balancer was used in 1960/62 Ford Passenger Cars, it was not used in anything else.
C3TZ-6312-E (replaced B5AZ-6312-B) .. Harmonic Balancer-Single Sheave (pulley groove).
Applications: 1957/58 Truck 272 / 1957/64 Truck 292 (except 292 H/D / 1955/59 Passenger Car 272/292/312 (except 1957 312 with dual quads or supercharger).
Old Jul 17, 2011 | 10:07 PM
TxF100's Avatar
TxF100
The actual casting # was ECG 6316 D1 which according the Damper Doctor's cross reference at Damper Doctor Online: Casting Number Interchange shows the ECG D1 to be for a Ford 292 Damper Doctor Online: FORD 292 C.I. V8
FYI the engine is a 1957 292 out of a Fairlane, so it looks like it is a cross reference match.
Bigbluedent1977
May 22, 2016 03:24 PM
Blackfoot Big Block
Dec 3, 2012 11:05 PM
98SurplusExpy
Feb 6, 2010 04:48 PM
gearhed1971
Aug 3, 2008 11:13 PM
deezel
2004 - 2008 F150
Apr 28, 2008 06:34 PM
