rusty oil pan
rusty oil pan
I should have caught this sooner but i have a pretty rusty oil pan. I thought it was just one spot but the rust is actually under the paint also! I realize this is a disaster in the makeing. I was thinking of sanding lightly and painting with a sealent of some type? help joe
I am currently fighting the same battle. The route of attack I'm taking is knock off the lose stuff, wire brush then some POR 15. The problem being, to replace it requires an engine pull. Some guys will will also say to use Rust Bullet too.
I'm hoping the POR 15 buys me enough time to save up for injectors so I can make one big mod weekend when I pull it.
oil pan
I have heard of rust bullit, but not the other product. My oil pan seemed to be rusted all over, not just one spot. And the dipstick tube is looking bad also. Not where the whole is in the pan, but going up the tube. Dont know if that can be changed or does the whole pan have to come off for that also? Thanks Joe
pan
Looks nice. Kind of stupid that the engine has to come out of the truck for that to be replaced.
As of now mine is not leaking. But it looks bad. I started to sand of the paint and rust. A few spots look bad and im not going to sand them anymore. My plan is to try the rust bullet and see if that will stop it from rusting thru. By me more time. I have been hit with medical issues too and now is not a good time for a very expensive repair. I have checked with a local diesel shop that has done a couple of small jobs for me and i was happy with. It wont be cheap but im going to be needing a clutch. I can have that all done at the same time and maybe change the up pipes when the engine is out. I dont drive my truck all that much now a days so maybe i can get more time out of it?
One thing i dont know is how thick the oil pan is? And where are the thin spots if any? And last question do you think the rust bullet is the best thing to try to stop the rust, since it is not leaking yet? Joe
just to help others out there. I had same problem a week after buying the truck . i ended up cutting out new metal and shaping it around the pan and cleaned off all the rust , then used plimbers dope to stop the dripping while i applied jb weld to the pan and the new steel patch. then painted over with undercoating . so far so good.
I'm in Minnesota and my pan was rusting badly. Sanded it down and used POR-15. That was three years ago and it still looks good, but I'll probably give it a touch-up this fall. One tip - buy the POR-15 in small cans. That way once you open a can you can use it all up, or if you do try and seal it back up and it dries out you won't lose much. I purchase a 6-pak of small cans off Ebay and chase corrosion somewhere on my truck each fall.
ok i have a idea about wat yall r talking about (sorry) but were exacley is the common spot for this? i just got the truck about a month a go oil still looking good but im gonna change it this weekend so is it inside the pan out just the out, and why exacley r yall having to pull the motor?
