Sponsored by: Real Truck
Uneven Front Bumper
Old Mar 29, 2003 | 12:10 AM
BluesManF250's Avatar
BluesManF250
Uneven Front Bumper
Today, I replaced the parking/turn signal housings on my 01' and put the clear 03' housings in. Easy swap. However, I noticed that my front <a href="http://www.motorhaven.com/">bumper</a> was uneven. I could slide my fingers completely under the housing on the left but not the right. Then when I looked at the front <a href="http://www.motorhaven.com/">bumper</a> from the sides, the right one does sit higher. Truck has never been in an accident or even bumped an object hard enough to move that giant <a href="http://www.motorhaven.com/">bumper</a>. I never noticed it before replacing the lamp housings.
Has anybody else noticed this on their truck???
Mike
Old Mar 29, 2003 | 12:26 AM
Yeti's Avatar
Yeti
Uneven Front Bumper
Didn't really pay attention to mine when it was new, and the <a href="http://www.motorhaven.com/">bumper</a> came off 10 minutes later to put the plow on.
If it's any consolation, they are very easy to adjust with only the 4 bolts out front.
Old Mar 29, 2003 | 01:29 AM
BluesManF250
Uneven Front Bumper
Thanks YETI,
Is it easy to just "bump" the <a href="http://www.motorhaven.com/">bumper</a> out of place? Reason I ask, I picked it up from the dealer today (warranty work) and I replaced the lamp housings right after that. I really dont think the <a href="http://www.motorhaven.com/">bumper</a> was uneven, but not 100% sure. I found no evidence of the fron end/<a href="http://www.motorhaven.com/">bumper</a> striking anything???
I am assuming that it would take quite a hit to move the <a href="http://www.motorhaven.com/">bumper</a> and some evidence would be present. Any more thoughts?
Mike
Old Mar 29, 2003 | 07:39 AM
hobert's Avatar
hobert
Uneven Front Bumper
Before you adjust make sure that the truck is sitting on a level spot. I've noticed with mine when the truck sits on a twisted parking spot the gaps change between the lights and the <a href="http://www.motorhaven.com/">bumper</a>s. I took notice to this even before I put the body lift on. I guess it's just the way the truck twists, nothing to worry about.
Old Mar 29, 2003 | 08:29 AM
BluesManF250
Uneven Front Bumper
I moved the truck to a confirmed level spot and the gap difference is still present. Are the four bolts for adjustment the ones right near the front tow hooks? Its strange, but from straight on, its not really noticeable, but from the sides it is. I just wonder if the dealership ran into something. Thats why I am curious about how hard an impact is needed to move the <a href="http://www.motorhaven.com/">bumper</a>. But, there is no evidence of a bump, ding, scratch, etc. I dont want too much time to go by, if it was their doing!
I just cant believe that I never noticed this before, especially when shining the <a href="http://www.motorhaven.com/">bumper</a>!
Mike
Old Mar 29, 2003 | 08:59 AM
Yeti's Avatar
Yeti
Uneven Front Bumper
Im not saying this happened, but it doesn't neceassarily have to be the <a href="http://www.motorhaven.com/">bumper</a> that was hit.
If the frame was tweaked, it would throw off your bumer also, remeber the <a href="http://www.motorhaven.com/">bumper</a> mounts to the frame rails, and more or less can move independently from the body.
But yes the <a href="http://www.motorhaven.com/">bumper</a> is easy to adjust, even easier if you have someone t hold it while you move it around.
My 10 year old daughter helped me when I put mine back on after my body lift install.
Old Mar 29, 2003 | 10:00 AM
warmdye's Avatar
warmdye
Uneven Front Bumper
Mine is crooked too. It has been that way since the day I bought it (brand new). The right side is about .5 in. lower the the left. It isn't something I'm gonna lose sleep over and I'm sure its gonna get alot more crooked in the years to come.
Old Mar 29, 2003 | 10:55 AM
PMR1730's Avatar
PMR1730
Uneven Front Bumper
Mine was crooked too, found out the same way when I rlaced the turn signal housings. If you loosen all four bolts next to the tow hooks the <a href="http://www.motorhaven.com/">bumper</a> will drop to its lowest position then you can adjust from there.
SUPPORT OUR TROOPS
Old Mar 29, 2003 | 11:54 AM
birdman127's Avatar
birdman127
Uneven Front Bumper
Don't forget there is two other bolts that I loosened before leveling off the <a href="http://www.motorhaven.com/">bumper</a>. There are 1 on each side inside the wheel well on the bracket holding the side of the <a href="http://www.motorhaven.com/">bumper</a>!
Old Mar 30, 2003 | 01:27 AM
BluesManF250
Uneven Front Bumper
Thanks for the input and the how to's! Sounds like the uneven <a href="http://www.motorhaven.com/">bumper</a> is not that uncommon. It was probably like that before I took it to the dealer. I will even it up when I get some spare time.
Mike
Old Mar 30, 2003 | 07:07 AM
birdman127's Avatar
birdman127
Uneven Front Bumper
Mike
Where at in Maryland are you from? I am 5 minutes from baltimore!
Old Mar 30, 2003 | 05:17 PM
BluesManF250
Uneven Front Bumper
Hi birdman127,
Hey thanks for the input on the bumper. I live just outside of Hagerstown.
Mike
muffett
All Things Towing
Apr 25, 2003 03:16 PM
Raintree55
Apr 24, 2003 08:38 PM
twix4x4
1978 - 1996 Big Bronco
Mar 28, 2003 11:38 AM
MEPR
Mar 26, 2003 05:59 PM
jpb222
Mar 25, 2003 05:02 PM
