stupid ? fuel pump
Old 07-13-2011, 09:31 AM
flainn's Avatar
flainn
flainn is offline
Originally Posted by srqdiesel chef
When I'm bleeding the system, I've been trying to bleed 2-3 injectors at once, So instead of doing 2 or 3 I should do 1 at a time so I can tighten up on it while I'm cranking the engine to avoid sucking air back in, that way 1 line at a time will get bled completely and I can go on to the next one...right?or will doing 1 at a time just prolong a process that has already taken way too long? aaaaaaaaaaaaaaa
I have had good luck doing half the injectors at a time (i.e., all the ones on the left side or all the ones on the right).
  #32
Old 07-16-2011, 09:04 AM
srqdiesel chef's Avatar
srqdiesel chef
srqdiesel chef is offline
it's me again, still can't get her going. I have done everything I can think of and it just won't start.I checked fuel flow at the filter head, 1/3 pint in about 8 seconds. I bled the IP , disconnected the left bank of injectors, the line out of the filter head to the IP, one of the injector lines at the IP, and trimmed and replaced the return line that feeds into the filter head (not all at the same time or in that order). I have fuel coming out of the filter head, but can't seem to get anything out of the IP. Is there anything else I can do short of replacing the IP and injectors ($$$), which I think is original at 360+k miles. All the grey paint matches.When I disconnected that line out of the IP, would there be any reason other than a bad pump not to get fuel spraying out? Sorry about babbling, really appreciate all the help.
  #33
Old 07-16-2011, 11:10 AM
srqdiesel chef
just bumping it up
  #34
Old 07-16-2011, 11:45 AM
bashby's Avatar
bashby
bashby is offline
Originally Posted by starmilt
It should click when you turn key on one time. The easiest way is to turn the key on and pull the wire off the pump, it should click when you reattach it, you can also leave the key off and use a jumper wire.
Did you do this?
  #35
Old 07-16-2011, 12:01 PM
srqdiesel chef
with key, not jumper wire
  #36
Old 07-16-2011, 12:26 PM
ihateminimumwage's Avatar
ihateminimumwage
ihateminimumwage is offline
So no fuel coming out of the injector lines at all, or does it seem like there isn't enough pressure from the IP now to make the injectors pop?
I'd also say do the jumper wire from battery to the FSS, just to know that's not the problem.
  #37
Old 07-16-2011, 12:30 PM
srqdiesel chef
no fuel at all coming out of pump
  #38
Old 07-16-2011, 12:57 PM
ihateminimumwage
Well, sounds offhand like your FSS isn't letting any fuel through. It clicked okay when you tested with the key?
Seems like even if the extra pressure from the new pump wrecked the IP, you'd still be getting something coming out of those lines, but I'm not an expert on the internals of the IP, so I could be wrong.
  #39
Old 07-16-2011, 03:07 PM
Marianna2003's Avatar
Marianna2003
Marianna2003 is offline
If there is too much pressure in the IP, it won't pump fuel. Some of the early DB pumps had a plastic bushing that would disintegrate, plugging the outlet. It would create a no start condition. Remove the overflow hose at the top of the IP to see if fuel is coming out there.
Before you burn up your $150.00 starter I'd temporarily install an Electric fuel pump:
Airtex E8090 - Electric Fuel Pump | O'Reilly Auto Parts
With it, all you have to do to prme your system is let it run for a half hour and it will push all of the air through the system.
PS:
I've used one to pump the fluid out of my E4OD before dropping the pan. Takes about 30 minutes but it's a lot cleaner.
  #40
Old 07-16-2011, 07:13 PM
ihateminimumwage
Exactly why I said I wasn't sure, good info to know...
  #41
Old 07-16-2011, 08:27 PM
Aune163rd's Avatar
Aune163rd
Aune163rd is offline
ihateminimumwage, question, how does that T-19 do for you? Is it wide-range or close? What gear ratio are you running in your axles?
  #42
Old 07-16-2011, 10:11 PM
ihateminimumwage
PM sent. Don't want to get off topic while someone is in the middle of a problem.
  #43
Old 07-17-2011, 11:04 AM
srqdiesel chef
ok, fss is clicking, looked at fast idle solenoid and it HAS got to be original, rust and corrosion rule the day, possible that has anything to do with this?overflow hose at top of IP? where dat?aaaaaaaaaaaaaagh now I'm going to napa to get starter on wife's nissan checked, thinking about buying a horse, at least if I have to shoot it we can have steaks for dinner
  #44
Old 07-17-2011, 11:13 AM
srqdiesel chef
for some reason I can't access page 3 of this thread unless I go to my email on yahoo, any ideas about that?
  #45
Old 07-18-2011, 07:20 AM
srqdiesel chef
alright, I'm biting the bullet and replacing the ip and injectors, I assume (I know what it means) I need to replace the FSS and the fast idle solenoid? or can I reuse what I got? I'm planning to buy the pump, reman injectors and the return line kit for about $500 total from Diesel Care Diesel Care Inc
Anybody know anything or bought anything from those guys before, any feedback will be appreciated.
Are the solenoids stealership only items, I can't find them anywhere else?
Quick Reply: stupid ? fuel pump
