Starting problem?
Old Jul 16, 2011 | 07:07 PM
lcattin's Avatar
lcattin
Well, it's been a week and the truck is starting well now. I still don't think that my GP's are working right but that is another maintenance item. I have a new set of Motorcraft ZD9's coming this week. Got them on ebay for $4.00 each. Put new connectors on the GP wiring this morning and if it still doesn't work well will built a new harness for them once the new ones are in.
Old Jul 16, 2011 | 10:57 PM
540milotalon's Avatar
540milotalon
As far as it goes, I installed an electric fuel pump in line with the mechnical and powered from the positive side of the GPR. It shuts off after 2 min. or less, however long the GPR stays closed. No problems after nearly 4 years.
Old Jul 16, 2011 | 11:00 PM
Marianna2003's Avatar
Marianna2003
Originally Posted by 84-6.9L
You can do the electric pump but make sure you bypass the old one so you don't fill the crankcase with fuel. Pull it out and get a block off plate for a small block chevy and it will plug the hole nicely.
Or simply leave it in and use it for a vacuum pump. I used my EP as an aux pump between the Mech Pump and the filter. I use it only when necassary. Once I get my Hydroboost installed, that's what I plan on doing when my vacuum pump goes bad.
Old Jul 17, 2011 | 01:41 AM
84-6.9L's Avatar
84-6.9L
I doubt it would have any great amount of volume, its ment to pump liquid and not really much else.
Old Jul 22, 2011 | 11:40 PM
Marianna2003
t's the same diaphragm and valves that the vacuum pump uses. Like you said, the volumn is low but it would be enough to operate the heater controls.
Old Jul 28, 2011 | 10:26 AM
lcattin's Avatar
lcattin
WooHoo!! No more starting problems now. I replaced all GP's last Saturday with Beru's. Now it starts up almost instantly. This is great. Thanks everyone for all the advice. Last thing to do is replace the cold start sensor which is bad. I will have that switch today and I am in great shape.
lindboep
Jul 28, 2014 02:29 PM
Orpackrat
May 10, 2013 01:48 AM
tomherrick
18
May 27, 2011 04:18 PM
rmdohen
Oct 4, 2010 08:00 PM
zhilton
Aug 11, 2010 06:09 PM
