Front Drive Axle
Front Drive Axle
Help!!! I am trying to replace the drivers side drive axle on my '02 Escape. The old one will not come out. I have tried using a slip hammer with no success. Does it require a special tool?
Remove the rotor and brake caliper (hang the caliper from the coil spring with a piece of wire so it wont hang by the brake hose), the big nut on the axle shaft, unhook the lower ball joint, the tie rod end and the strut. The axle should pound right out. Be careful not to mushroom the end of the shaft or damage the threads with your hammer. I usually use a large brass drift punch and a big hammer. It helps to have an assistant hold the hub assembly out a little bit so that you dont damage the transmission or cv joints.
There is a retaining clip on the transmission end of the shaft that holds it in place. Like Rickfar says, just pry it a little. Be careful not to damage the seal on the transmission with your pry bar. If your replacing the shaft, its a non issue but if you need to use the shaft again, you should be careful not to over extend the cv joints as they can come apart inside the boot.
shamp
May 1, 2010 04:03 PM
SoArkSI
Sep 15, 2006 08:16 PM
Txbullfrog
May 22, 2004 08:46 AM
Manwith3fords
Mar 15, 2004 06:01 PM
