new to site
Just discovered this site. I just bought a 1978 F250 4x4 and am sure I will be a frequent visitor. According to the VIN decoder, this truck was an original I6 300 CID truck, but now has a 351W. It's also a 4-speed. I pick it up on Friday and will post some shots.
Thanks
Frank
351W eh? You might as well know now that Bumpsides (67-72) and Dentsides (73-79) were never offered with a 351W. If your plan is to install headers, the closest you'll get is a 302 application or Windsor shorties. The former in long tube would need to be modified for the increased one-inch taller deck height and the corresponding flare / splay in width.
Post up your rigs' specs and I recommend you include it in your signature so we can respond and respond faster to what ever questions you may have. Again, welcome.
The VIN is F28BEBE288830 (the doors on this truck were replaced and the VIN plate was obviously taken off and put on new door as the VIN rivets are nothing like stock).
The engine is a 351W and has a code E4AE 6015 PA-5. Like I said, this is my first Ford, but I think that equates to a 1984 engine. Not sure what it came out of. It has a Holley 4-bbl on it, again, not sure if that’s original. The vacuum hoses are a mess. It looks like all the lines off of the EGR were just plugged up with bolts. Is there a vacuum routing diagram for this engine, and would it be of any help since the engine is 6 years newer than the truck?
It looks like there is a missing power steering bracket (there is something homemade there but the belts don’t line up). Is that bracket available?
The wire for the temperature gauge was all corroded at the end where it connects to the sending unit (the rubber boot is there, but the connection inside crumbled away). Is this connector available so I can just splice it in?
The radiator looks like it is in good condition, but it has the fittings for an automatic, so it is probably not original.
The front brake lines were replaced (still have NAPA tags on them) but they were bent very sloppily. Does anyone make a pre-formed kit for trucks? I’m used to restoring GTOs and most everything is available for them. J
It has headers on it, with dual exhaust and glasspacks. Are the stock exhaust manifolds available, and if so, do I get them for a 1984 351W? How will I know if they will fit in a 1978 F250 truck?
The engine leaks oil and there is a pool on top of the timing chain cover. I think it is actually coming out of the timing chain cover as that gasket sort of crumbles in my hand.
It has a PCV valve in the pass. Side valve cover, and a breather in the driver side one. Is that correct? The air cleaner is barren, with no clips in it, but multiple holes and vacuum fittings. The flap in the snorkel has been removed.
The seat is firm, but has a rip in it. Who makes seat covers for these?
Appreciate any recommendation or insight into getting her running clean. I’m not trying to build a show truck, but I want the engine compartment to look decent without plugged up vacuum lines and oil leaks. Any recommendation for online parts resources would b much appreciated.
As soon as I figure out how, I will post pictures I took today.
Frank
In response to some of the questions above:
If your rig is exempt from emissions, delete as many vacuum lines as possible.
Salvage yard for a bracket.
Salvage yard for a connector or whatever works since this isn't a resto.
Check with Inline Tube or Classic tube for hardlines and brake hoses.
351Ws didn't change much over the years. You can play it safe and look for 80s era manifolds... Plenty of those in the yards. Otherwise, keep the headers since they are worth HP.
Check the catalogs above for seat covers.
