Sponsored by: Auxito
wont start
Old Jul 4, 2011 | 10:17 PM
paulywauly68's Avatar
paulywauly68
wont start
i have a 97 f150 4.6 l auto transmission truck had issues first the brake lights wouldnt come on 2 nd the truck would start in park but couldnt be put in gear so i would start the truck in neutral then put it in gear it also recently had a code of p1409 checked for any air leaks in lines cleaned out the parts that deal with the code
i replaced switch by brake pedal checked fuse on end of master cylinder was good i then replaced a couple fuses in fuse box and now when i try to start the truck it doesnt click or try to start i took the fuses back out that i had replaced it doesnt help
Old Jul 5, 2011 | 09:41 AM
paulywauly68
ok back at it again changed out parts associated with p1409 code changed out all the fuses in all the locations under the hood and in the truck runs better but still not real well hasnt thrown out any check engine light as of yet but still running like its not firing right
77_F150_4x4
May 13, 2014 01:36 PM
giants17068
Jun 26, 2013 07:23 AM
bcmchong
13
Dec 27, 2010 02:20 PM
bcmchong
Dec 26, 2010 04:05 AM
finster725
1997 - 2003 F150
Sep 1, 2003 08:01 PM
