proportioning valve
Old 08-05-2011, 12:21 AM
arrowheadfred's Avatar
arrowheadfred
arrowheadfred is offline
proportioning valve
The under frame disk/disk booster i have should have a built in proportioning valve BUT i'm not so sure . Even if it has one built in would it hurt to add a adjustabe one ? If so what brand should i get ?
Old 08-05-2011, 11:28 AM
ZOOT's Avatar
ZOOT
ZOOT is offline
Is your brake system completed now? Can you drive the truck? If so, the test would be to hit the brakes and see if the disc brakes on the front are working before the rears. Try it in an open parking lot because if the booster doesn't have the proportioning valve, the rear end will start to slide to one side because the rear brakes are not working. An adjustable proportioning valve is needed. Speedway sells them. They sell quality products so I would trust them. Summit sells them as well as many other suppliers. Just don't buy an off brand. The valve on booster ( if there is one ) is preset so adding another one will change the pressure ratio. Hope that helps.
Old 08-05-2011, 09:36 PM
mytbtruck's Avatar
mytbtruck
mytbtruck is offline
I am using an adjustable proportioning valve from Summit. It is made by Stainless Steel Brake Co. I have front disc and rear drum brakes. I works very well and I am satisfied with it
Old 08-05-2011, 09:49 PM
arrowheadfred
Thanks guys !!! I have new everything on my truck but i can't power brake it cause it just won't hold it back and with 4 wheel disk you would think it would .So something ain't right. I have good brakes but they could be better.
Old 08-06-2011, 10:15 AM
ZOOT's Avatar
ZOOT
ZOOT is offline
Sorry for being stupid but what does "I can't power brake it because it won't hold it back" mean ? Should be same pressure to all corners if it's all discs. Maybe I'm wrong,(not the first time)but the whole idea of a proportioning valve is to balance difference in pressure needed for a drums in the rear and discs up front. I can't see what purpose a proportioning valve would have in a four disc set up. It should stop on a dime with four discs.
Old 08-06-2011, 01:07 PM
Lakotas53's Avatar
Lakotas53
Lakotas53 is offline
LOL power braking is you keep the front brakes locked while you break the rear ones loose for some really great smoking burnouts!
yellodog
07-01-2015 09:20 PM
JustBlaze
12-14-2010 08:55 AM
FLN
09-07-2009 12:03 PM
yield2s
09-10-2008 08:20 PM
GeneStoner
06-09-2005 09:56 PM
Quick Reply: proportioning valve
