2010 fuse problem
Old Jul 3, 2011 | 05:59 PM
Texasefain's Avatar
Texasefain
2010 fuse problem
I had a new windshield installed and the first time it rained, my auto unlock,the tire pressure moniter and the auto headlights stopped working. The dealer said that the fuse box got wet. I have since fixed the leak but can't find a fuse or reset any where. Any ideas?
Old Jul 3, 2011 | 06:02 PM
Jus2shy's Avatar
Jus2shy
You do have a fuse box/smart junction box on the passenger side kick panel, Did you check that? Also, did you make sure the lid is shut on your under-hood fuse box? I find that it's the simple things that tend to be the issue...
Old Jul 3, 2011 | 06:09 PM
Texasefain's Avatar
Texasefain
yes, i looked at the fuse map in my manual but dont see a fuse for these items.
Old Jul 4, 2011 | 10:30 AM
NotMyHusbandsF150's Avatar
NotMyHusbandsF150
A little off topic but how low do your tires have to be for the TPM to go off... on our '04 NBX, it goes off just under a pound or two but on my '10 150, after some mudding a couple weeks ago, both front tires were a little low 3-4 lbs and the sensor never went off. Could that mean something is wrong with the sensor or is it not as sensitive? Make sense?
mbritt
Nov 19, 2006 07:13 PM
Airconditionedgypsy
1997 - 2003 F150
Oct 26, 2006 04:03 PM
bokker
3.8 & 4.2L V6
Apr 8, 2006 03:03 AM
nicko36
Aug 27, 2005 04:07 AM
