Sponsored by: Auxito
98 F150 Temperature Adjust Switch
Old Mar 28, 2003 | 03:46 PM
mhlynch's Avatar
mhlynch
The temperature adjustment switch (the damper) seems to be sticking. When turning the switch, the switch seems to give without actually turning the damper. If the switch is worked back and forth slowly, it finally seems to be adjusting the damper. Is there somewhere that the damper adjustment can be lubricated, etc.????
Old Mar 29, 2003 | 12:17 AM
Racerguy's Avatar
Racerguy
Pull the **** off the temperature control and see if it is cracked. I've seen that before. The **** turns but doesnt turn the shaft that it fits on.
