75 G-Machine
Old Jul 2, 2011 | 03:07 PM
martin0605's Avatar
martin0605
75 G-Machine
Heys Guys,
I am wanting opinions on doing a G-Machine out of a 75 F-100 that I have. I posted in the drag trucks section,but I think the G-machine would be a better driver and more enjoyable.
I am wanting to graft on a (gulp)67-72 chevy front and rear suspension,aka NASCAR,with upgraded suspension components from Hotckis.
What do you guys think? All opinions are takin.
This is what I'm shootin for.
Classic Lines With Pro Touring Prowess | Street Trucks
Thanks,
Mike
Last edited by martin0605; Jul 2, 2011 at 03:16 PM. Reason: Or maybe like the no limit engineering 56 Ford.
Old Jul 2, 2011 | 07:07 PM
73FordF100's Avatar
73FordF100
Well first off, what is a "G-Machine", I've never heard this term? Are you talking about like a pro touring truck? My opinion is that you should keep it all Ford, with exception to upgrades. Many people have grafted in the Ford Crown Victoria front suspension on the existing frame rails and it seems to be the most popular thing to do to these trucks to lower them and make them handle better. If you wanted to upgrade the rear you could add ladder bars, a rear sway bar, drop shackles or put the axle on top of the leaf springs (to lower the rear), and even put rear disk brakes on it (I think there is a kit you can buy to convert the rear). That's just my $.02 and all I can think of right now.
Old Jul 2, 2011 | 11:31 PM
HIO Silver's Avatar
HIO Silver
Originally Posted by martin0605
Heys Guys,
Thanks,
Mike
To the poster above, a "G-machine" is a term used to describe a vehicle that is built/modified to pull high a high G on a skid pad... a good handling vehicle is typically rated at more than .88 G.. where G is the measure of lateral force. For example 1G would mean the lateral force is equal to the vertical force.. and the vertical force is equivalent to the force of gravity.
To the OP, I suggest you either start with a Chevy or simply replicate a NASCAR chassis.. it'll need to be low and wear really wide and sticky rubber.
The biggest enemy will be weight and weight distribution. Some ways to do that include moving engine back, moving the front wheels forward, swiss-cheesing the frame, and shedding as much weight as you can. You'll also need a close ratio transmission, fat anti-roll bars, big brakes, and a limited slip if you want to be competitive in road racing or autocrossing... Ya'd better be starting with a shortbed.
Old Jul 3, 2011 | 12:16 PM
martin0605's Avatar
martin0605
Ok guys,
The term "G-Machine" or Pro touring is just for reference I used to descibe the direction of the the build I wanting to do.
Any way thanks for the feedback.
Hi0 Silver,starting with a chevy and replicatin a NASCAR chassis is out of the ? I looking to build it that way,but with more streetability. It will replicate a NASCAR style,but not with so much technology.
Basically a stock Ford frame with the front and rear clipped with the suspensions and the upgrades accordingly.
The Ford in the link I provided did not have all of that,just more civilized to drive.
I just want to go a little further and do something a little different than the norm or building a Chevy,everyone has played out the Chevys and I am a Ford guy.
As far as I know,no one has done this before.
Thats the reason for wanting an opinion,wether good or bad. I wish I had a pic of what I am trying to build there might be a better understanding.
Thanks,
Mike
WillW4169
Mar 16, 2015 10:13 PM
WillW4169
33
Feb 27, 2015 08:00 AM
airharley
15
Aug 19, 2013 02:25 AM
blueovalblood
66
Jan 24, 2006 01:18 AM
