Pitman arm troubles
Old Jul 2, 2011 | 12:40 AM
Lumpy78's Avatar
Lumpy78
Pitman arm troubles
Ive got a 1973 f-250 and i put a lift in. I cant get full turning abilities to the left, they told me i need to find a longer pitman arm or made for a lift...but everywhere i have looked i cant seem to find and thing for my year of pick up...any suggestions? Thanks
Old Jul 2, 2011 | 06:34 AM
650's Avatar
650
If I remember right Bronco Grave yard sells some drop pitman arms.
Old Jul 2, 2011 | 09:30 AM
skidoodave's Avatar
skidoodave
If you can't get a drop pitman arm you may be able to get an adjustable drag link which would do the same thing. If you can't, then you might have to cut and length'n your drag link.
Old Jul 2, 2011 | 11:54 AM
PA74F250's Avatar
PA74F250
For that style D44 you can get a 3" block that goes beneath the steering arm. It's made by superlift and last time I looked JBG sells them. I don't know if they come with longer studs or not. If you have some sky high lift it maybe not enough but I'd bet that will compensate enough.
Old Jul 2, 2011 | 12:03 PM
PA74F250's Avatar
PA74F250
Check it out
Dana 44 3 Inch Steering Block
Old Jul 4, 2011 | 09:22 AM
Hyperactive460's Avatar
Hyperactive460
what does your pitman arm look like ? i have one from an early 77 model that is about 2" longer than the one you have( that is if yours drops straight down ).
2001SuperDuty
Jan 31, 2019 01:12 AM
ConnerSmith
Jan 4, 2015 07:12 PM
ashleyroachclip
WTB - Parts & other
Aug 18, 2014 06:08 AM
Kommandant
Mar 30, 2012 04:53 AM
ttttmaxx
Jul 22, 2010 11:08 AM
