Specifications Questions--1957-60
Old 07-01-2011, 09:58 PM
Bobs65F600's Avatar
Bobs65F600
Bobs65F600 is offline
I have searched through my shop manuals and on line. I cannot find specs and/or dimensions for the 57-60 F-series trucks. Chevy folks have the "old manual project" or something from which to draw. I've found all the info in the world on Chevys from 47 through at least 59, but nothing similar for Fords.
In particular, I'm trying to get cab-to-axle measurements among others. I'd like to see what bed might fit on my truck. It measures right at 60" from back of the cab to the center of the rear axle. The frame is just at or slightly over (within an inch or two) of 96" from the cab to the end of the frame.
Any help is appreciated.
Old 07-01-2011, 10:56 PM
ibuzzard's Avatar
ibuzzard
ibuzzard is online now
Panties NOT in a Twist
Bob,I've got your dimensions from the 1959 Competitive Comparison Manual.
134" Wheelbase: Cab to Axle,60.5"
Max. Side Rail Dimension-in.depth,7.08
Section Modulus, 6.24
They also list a 154" wheelbase.Steve
Old 07-01-2011, 11:15 PM
truckdog62563's Avatar
truckdog62563
truckdog62563 is online now
Marmon-Herrington Man
What model are you looking for? I've got the 1957 Body Builders Layout Book that shows the F-350 and F-500 are 60.5" from back of cab to the center of the rear axle. But the wheel base is 130", not 134". Back of cab to end of frame is 99". If you need it I can do a scan tomorrow and post it. Stu
Old 07-01-2011, 11:18 PM
Bobs65F600's Avatar
Bobs65F600
Steve...thanks! Do you have access to the same dimensions for the F-350 with an 8' pickup box? All I can find is 118" WB to compare to my truck's 135" (I measured 132"...pretty close!)
Old 07-01-2011, 11:20 PM
ibuzzard's Avatar
ibuzzard
You're correct,Stu,my bad.
Bob,F-350 has a wheelbase of 130 inches.Cab to axle is 60.5".Max.side rail dimension is 7.0 ".Section modulus is 5.27".
Steve
Old 07-01-2011, 11:23 PM
Bobs65F600's Avatar
Bobs65F600
Stu...if you can scan and post, that would be great. If you have the dimensions for the cab to axle center of a truck that carried an 8' styleside or flareside bed that would also help me.
Bob M.
Old 07-01-2011, 11:37 PM
truckdog62563
The F-350 schematic is SRW, and drawn without a bed. As I understand, the book's purpose was to allow aftermarket companies to design products to fit the chassis. Thus no beds are shown in any of the drawings. I'll have to take the book to a good copier to reduce the size of the drawing. Tomorrow is breakfast with the guys, so I'll go to Staples afterwards. Stu
Old 07-02-2011, 12:19 PM
truckdog62563
Here's the chassis schematic for the F-350, and the cab schematic for the light and medium duty models. Stu
Old 07-02-2011, 06:58 PM
truckdog62563
If your lap top is like mine, the numbers won't be real easily read in these charts. They are clear on one of my computers, but not on the other. If you think this info is useful, but can't read it, I'll send you a hard copy that is readable if you want. Do me a PM with mailing info. Stu
Old 07-02-2011, 09:11 PM
Bobs65F600's Avatar
Bobs65F600
This is amazing! I will have to send you the e-mail--it's pretty "cluttered" with all that data!
Now...let's see if I can do this...
muddin83
36
04-02-2011 07:55 AM
BlueOvalBud
05-16-2010 08:55 PM
57phil
02-21-2008 11:26 AM
daddyo4
10-26-2007 10:05 PM
badtomatoes
04-19-2006 08:11 PM
Quick Reply: Specifications Questions--1957-60
