Shaky Hood
Old Jul 1, 2011 | 06:25 PM
tcp4u's Avatar
tcp4u
Shaky Hood
Is it normal for the hood to shake at interstate speeds? Everything seems to be tight. Tires aren't new, but not worn out ether.
Old Jul 1, 2011 | 07:11 PM
CaptFX4's Avatar
CaptFX4
What do you mean by shake? A common thing i've seen with these hoods looks like a flutter. It happens on my 2005 Screw. I've just been to lazy to fix it. There is a TSB that says to take the black seal off from under the hood and insert a piece of fuel line. I guess the seal is too soft and the fuel line firms it up a little. I will try to find where I saved the TSB and post it.
Capt
Old Jul 1, 2011 | 07:18 PM
CaptFX4's Avatar
CaptFX4
Another question, do you have a bug shield? They say that a bug shield will amplify the flutter.
Anyway, here it is...
TSB 04-18-8
FORD: 2004 F-150
ISSUE:
Some 2004 F-150 vehicles may exhibit hood movement at the back of the hood due to high air turbulence, while driving at highway speeds. This condition may be amplified by the installation of an accessory bug shield and may be more pronounced when passing an on-coming vehicle on a two lane road.
ACTION:
Refer to the following Service Procedure.
SERVICE PROCEDURE
Confirm that the hood is flush with the front fenders at each front corner. If the hood is under-flush, adjust the hood stops to raise the hood flush with the tops of the front fenders.
Check the amount of drag at the rear hood to cowl seal with a piece of paper. Place a piece of paper between the seal and hood, close the hood and then slowly pull the paper out.
If there is sufficient drag, indicating good seal to hood contact, return the vehicle to the customer.
If there is little to no drag, obtain locally a piece of fuel hose 147 cm long & 11 mm diameter (58" long & 3/16" diameter). Lube the hose with a soap-based solution and install the hose inside the hood seal bulb.
Hope this helps. If not, you may have bigger issues.
Good luck!
Capt
Old Jul 2, 2011 | 06:41 AM
tcp4u's Avatar
tcp4u
I do have the bug screen and that's probably all it is. Thank you much
Old Jul 2, 2011 | 03:56 PM
2004 xlt 5.4's Avatar
2004 xlt 5.4
Mine did it as well add the fuel line it will help a lot.
AZmadman
Nov 24, 2006 01:48 PM
RubberDuck
Appearance & Dress-Up
Feb 18, 2004 10:37 AM
jowilker
Sep 4, 2001 07:10 AM
Franklin2
Jul 15, 2001 08:17 PM
