Scanguage II
Old Jul 1, 2011 | 07:11 AM
onuredneck707's Avatar
onuredneck707
Scanguage II
As a follow up to a previous post of mine, I had the wrench light come on and when I turned the truck off and back on again the light went away and has never come back on. Some folks on here suggested that it may be a plugged oil cooler. I took the advice of some folks on my previous post and bought a Scanguage II tool. I just got it yesterday and installed it this morning.
How do I get it to read the ECT and EOT? I see there is a WT built in. Is this the same as ECT? I am looking for no more than a 10 deg differential in these two parameters correct?
Thanks for the help. By the way, I am excited about the Scangauge, it looks like it will be very helpful!
Old Jul 1, 2011 | 07:25 AM
npccpartsman's Avatar
npccpartsman
I urge you to read this thread: https://www.ford-trucks.com/forums/1...injectors.html
It has a list of PID's (codes) for programming the X gauges. EOT is one you'll have to program. Coolant temp is fWT or cWT depending if you're reading in farenheit or celsius. The temp spread is 15*--take it with a grain of salt and use some common sense. You can have a larger spread if you've been pushing it hard and then back off. The coolant will cool much quicker than the oil. If you had a wrench light it stored a code of some sort that the SG2 may or may not read.
Old Jul 1, 2011 | 07:51 AM
rattleNsmoke's Avatar
rattleNsmoke
Gonna steal this thread for a moment.............I have an eroneous reading on my Scangauge when BST or boost reading is selected and I put my foot into it. The Scangauge will read a - number until I back off a bit then it will read properly. Anyone have the same issue, or did I program incorrectly or perhaps there are alternative codes to use?
Old Jul 1, 2011 | 08:09 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Chichi the thread partsman mentioned above. It's kinda long but good info to know. There is an issue with boost relative to MAP/MAF and a couple of ways to work around. I haven't worried with it because factory boost gauge is suppose to be fairly accurate.
Old Jul 1, 2011 | 08:12 AM
Rusty Axlerod
Check...check the thread..... (stoopid spell checker).
Old Jul 1, 2011 | 09:23 AM
steelhead2's Avatar
steelhead2
I get a -.02-4 when idling,but I don't worry about it.the fwt is the water temp.get ready to look into the crystal ball and see good......and bad things.hope it works out for ya,its a neat little gadget.
Old Jul 1, 2011 | 03:16 PM
onuredneck707
The Scanguage did not see any codes when I plugged it in today. Thanks for the help on this. I will try it out tonight!
Old Jul 1, 2011 | 07:49 PM
onuredneck707
So I added the EOT to the Scangauge and took her for a drive when I got home from work. Once warmed up it looked like I was running about 217 EOT and 197 or so on the ECT. I would imagine this indicates I have a cooler issue correct? I am going to let the truck sit overnight and see if they stabilize together in the morning to ensure my sensors are correct, but I would imagine I will be replacing the oil cooler soon. Should I try to avoid driving the truck in the mean time? I don't tow anything or drive it hard. Just 20 miles to work.
Thanks!
Old Jul 1, 2011 | 09:17 PM
rattleNsmoke
The delta (spread) from all I've read here has a lot of interpretations. I'd run it a few more times on the level at hwy speeds to see if that changes.
Old Jul 1, 2011 | 10:54 PM
Rusty Axlerod
I agree with rattleNsmoke- wouldn't park it just yet- reason being your temps are low (not overheating). Delta is 20 and that ain't good but EOT of 217 is ok. I just pulled my 10k fifth wheel a couple of hours in upper 90's outside temps and saw 230 EOT a couple of times. I ain't freaking.....really...much.
