8.8'' help!!
Old Jun 30, 2011 | 10:47 PM
ktm747's Avatar
ktm747
Exclamation 8.8'' help!!
last night i was driving my 94' f150 loaded down with a car hauler and my 77' f150 up a pretty steep canyon and about ten miles up it i started to hear a popping sound come from the rear end whenever i shifted gears or pressed the clutch. it did this all the way home thankfully the rear end didnt blow up. when i did get a chance to pull the cover i discovered the pin in the diff sheared through. to replace it do I need to pull the whole diff and axles out or what? This is the first time i have had trouble with this axle so i am not familiar with it. how do i fix it and put it all back together without screwing it up any help is much appreciated.
Old Jul 1, 2011 | 10:28 AM
subford's Avatar
subford
What pin did you shear (lock bolt or differential pinion shaft)?
Is this a LS or open rear end?
No other damage?
Pearlwhite94
Jan 9, 2015 03:53 PM
96f15013ddie
Oct 1, 2013 08:22 PM
pwrplay
Mar 20, 2013 09:05 PM
stratus225
2004 - 2008 F150
Nov 11, 2007 09:52 PM
bustech81
Dec 24, 2006 06:35 AM
