TRANNY FLUID?
Old Dec 7, 2002 | 01:57 PM
mpb_27's Avatar
mpb_27
TRANNY FLUID?
I bought an 89 f150 w/ 302 and 5 spd tranny. The truck "whines" through the gears. What could be the cause of this? Also I was told that some Ford Man.Trans. use ATF fluid?
Old Dec 7, 2002 | 02:41 PM
steve83's Avatar
steve83
TRANNY FLUID?
Check the owner's manual for the right fluid, but more often it's a front wheel bearing.
Old Dec 7, 2002 | 02:53 PM
mpb_27's Avatar
mpb_27
TRANNY FLUID?
I know its not a bearing.It only does it in gear, when i push the clutch in to shift it stops,when the clutch comes out it starts again. except 4th gear.
Old Dec 7, 2002 | 02:56 PM
steve83's Avatar
steve83
TRANNY FLUID?
You're right - that sounds like the front main bearing of the transmission. Which one do you have? The M5OD (normal 1st gear) or the ZF (granny 1st, with OD)? If you don't know, post the TRANS code from the bottom line of the VIN sticker in your door jamb.
Old Dec 7, 2002 | 03:22 PM
mpb_27's Avatar
mpb_27
TRANNY FLUID?
m50d
Old Dec 7, 2002 | 04:41 PM
GammaDriver's Avatar
GammaDriver
TRANNY FLUID?
