New Autoenginuity user
Old Jun 29, 2011 | 03:07 PM
Headviking's Avatar
Headviking
A couple of days ago I received my new AE and am testing it out. Well my FICM is at 47.5. With the engine at operating temps on the road doing 60 my EOT is at 198.3 and ECT is 197.1. I think I need to replace my thermostat (running too hot). Either that or I have the closest delta's between the two.
Any comments on the temps. I will be testing it out on a longer run maybe 1/2 hour doing 70, to see what I get.
Thanks Mike for your great work.
Old Jun 29, 2011 | 03:53 PM
dchamberlain's Avatar
dchamberlain
First thing I think is to check the oil, coolant, transmission and both IAT and IAT2 after the truck has cold soaked overnight. They should all be pretty much the same. That'll eliminate any possibility of sensor error.
The next question is what was the outside temp when you were driving and getting ECT of 197. Unless it was really hot, then I think there is a cooling problem. My truck, just cruising at 65 or so, runs right about 190-192, unless it's really, really cold then it'll drop down to 188. If it's excessively hot (90-100) outside, it might run up to 194. But that's unusual.
Old Jun 29, 2011 | 05:09 PM
texans's Avatar
texans
I have always run 190-192, but here for the last month we really haven't had a day under 100 out side, and I noticed that my ECT has been running 195-205 driving down the road.
Old Jun 29, 2011 | 05:15 PM
m-chan68's Avatar
m-chan68
That sounds about right.
Old Jun 29, 2011 | 05:23 PM
Headviking's Avatar
Headviking
The outside temp was 73* when I made the run. I am on holidays next week so a flush is in order with a thermostat replacement. Then I'll run it again.
dchamberlain
Temps like that are pretty rare here. And I just did my new thermostat last spring. So what he is seeing may be perfectly normal.
Old Jun 29, 2011 | 06:55 PM
Headviking's Avatar
Headviking
But the spread between is close. Is this normal? Or has my mechanic been very good to my truck? With the help of my coolant bypass of course!
oft
Oct 20, 2014 05:30 PM
stimm32
Aug 29, 2013 01:11 PM
largefries
16
Mar 14, 2007 06:23 PM
twinarrow99
1983 - 2012 Ranger & B-Series
Apr 11, 2006 09:32 PM
Randy Jack
22
Nov 9, 2004 10:10 PM
