Sponsored by: Auxito
Suspension warning light
Old Jun 29, 2011 | 12:46 PM
koden's Avatar
koden
Last year I removed the suspension airbags on my 97 F250LD and had a shop install 3/4 ton springs for the truck.
Since the truck sits a little higher than before the suspension warning light stays on. I'd love to get rid of that warning light. Does anyone know if I can clip a wire that is going to that light to make it go away? Does the ECU handle that or is there a seperate controller for the optional suspension airbag system that I can pull out?
Thanks for the help.
Mark
Old Jul 1, 2011 | 02:06 PM
Bluegrass 7's Avatar
Bluegrass 7
If you will look at a Haynes service book on page 12-30 top of page you will see a 5a fuse #2 that powers the line and the 'check suspension' lamp.
The ground for it comes from the rear air suspension module.
The color codes are there for you to try to find and cut open to see if that puts the lamp out.
Lead color code in my book shows it as dark green/light green tracer.
Find that lead at the module and open it.
I don't think any ground is possible from the data link connector.
You can't pull the fuse because it powers other functions in the dash.
Good luck.
Old Jul 1, 2011 | 03:15 PM
koden's Avatar
koden
Great info Bluegrass. I looked at my Haynes and could not find it. I'll check it again and confirm.
Thanks!
Old Jul 1, 2011 | 11:33 PM
Bluegrass 7
Back of the book in chapter 12, page 30 (12-30) in larger script at the top of the page.
Daniel Bente
Jan 3, 2016 05:50 PM
rmccbride
2015 - 2020 F150
Apr 25, 2015 06:38 PM
mudduc971
1997 - 2003 F150
Mar 12, 2014 12:43 PM
shore
Mar 17, 2013 11:15 AM
jamesmonroe919
Oct 26, 2006 07:40 AM
