Joe, that has got to be one of the prettiest trucks around, I love the woodwork on it! I've been around woodworking a little, and I know how tough it can be to make something that nice looking. The wood bed compliments the cab color nicely too.
Sam
Thanks Sam
It's not perfect, but as I tell folks, 'I'm not a craftsman, I'm a hobbyist'.
I looked at all your bed construction pics again. Is your bed 12 feet long? And does it extend beyond the rear of the truck frame about a foot or so?
Yes it does, it appears that at one time somebody cut part of the frame off at the back. When I got the truck, the steel flatbed hung almost 4 feet off the frame. Since I don't intend to carry any real weight the 2 3/4" x 6" oak beams will easily support it.
My truck frame extends 8 feet from the cab. If it's supposed to be 9 feet long (which I really don't know) then someone cut it off too. But if I make a wooden bed for it, it won't be a big deal, I'll never haul any real weight with it either.
Did you get your oak from a mill? I noticed the TN plates. I am in southern CA, and no one here has ever seen a sawmill. You mentioned you had ready access to the wood, or already had it. What types of wood would you recommend for a bed, if I can't find oak in that size? And I think it's worth repeating... that bed you made is beautiful.
Yes, I got all of the wood from a local sawmill (5 miles from my home) I used oak for it's strength, availability and appearance. Pine was used by Ford on a lot of these old trucks, but I would not recommend it for the structural (frame) sections. Sawmills are all over the place yet few ever advertise. I don't know where one's close to you are, but here are some sources to check out. Find a sawmill in California if none of these are real close, you may want to contact one or nore of them and inquire about mills close to you. If you find a mill close but don't have a planer, the mill should be able to give you info on somebody close to plane lumber. Here is another list WOODWEB's Sawing and Drying Directory
OK, I take back what I said about sawmills in CA. Two of these are within 60 miles of my house.
Thanks for the references.
I would call them as they may know of some even closer to you. As for the type of wood to use, you really want a good hardwood if you're using it for the framework. Talk to the mills about what hardwoods are available in your area.
I may have a line on a flatbed for the truck. It measures a little over 6' 7" x 8' with beams 34" apart (matches the truck chassis). It's a foot shorter than a stock Ford 9' bed, but I think it will look ok.
